I have a Beogram 4002 with a platter speed problem - during playback at 33 1/3 it slows down dramatically. I have changed both belts for new ones and cleaned the sub platter and motor spindle to ensure no slipping is happening. When I increase the speed with the trim pot things inprove for a while but eventually things slow down again. Things seem to be ok on 45rpm but 7" singles may not be long enough to show up the problem.
Therefore I assume this is a trim pot issue - does anyone have any expereince of this?
I have removed the trim pot assembly to see if there is any adjustment but the unit appears to be sealed - am I correct?
Your help is much appreciated,
Matt
