halid:- Do I need to set L. OPT in any mode just to be sure ?
I do not think so. L.OPT is only used for Link only speakers.
 halid:- Do I need to press LINK DVD on the 7-32 as well ?
If you have a Master and a Link TV in the same room, pressing LINK insure that only the link TV picks the signal.
I suggest you put the BV6 in the same room as the master, just because it is the easiest way to make a simple direct connection.
LINK is also used to get a distant source from a Link room, when the same source is present locally. For example, pressing DVD in front of the BV7-32 will activate its DVD, pressing Link DVD will activate the BV7-40 DVD.
 halid:- Do you mean that I should set the 7-40 as master when I connect the BV 6-26 to it ?
 It is the case already I think... Option 2 means Master.
Here is the output of the PCG. Some indication might be wrong as I do not know the exact version of your products.
************************* VIDEO SYSTEM SETUP **************************
BeoVision 7 - 40"MKIII
BeoVision 9
DVB-T/S
Connection Video
Please note: BeoLab 7-2 must be connected to "Power Link Centre"
(not "Cinema Centre"!).
Display 1-2 (DVI-D out).
Connector for screen or projector.
A screen is connected to Display 1 and projector must be connected to Display 2.
HDMI-IN (A-D) (High Definition Multimedia Interface).
The HDMI sockets can be connected to any HDMI video source or PC.
Please note:
You can view 2 HDMI sources at the same time.
The TV requires a DVB-T/S kit:
Type 4384
IR IN.
Connect the receiver cable to the IR-socket and plug it into the
6-pin terminal block of the IR-eye.
IR1+2.
The socket is used to check the IR-signal to the projector.
AV1 - AV6.
AV1 is used for AV connection of equipment such as a DVD recorder, VCR, HDR or
set-top box. (V MEM). 2-way communication from TV to product connected. AVL.
AV2 is used for AV connection of additional equipment such as a
digital satellite receiver (DTV).
1-way communication from TV to the product connected. AVL.
AV3 is used for AV connection of additional equipment such as a DVD player.
AV4 is used for AV connection of additional equipment. 1-way communication
AV5 is used for AV connection of additional equipment such as BeoMedia or a PC.
AV6 is used for AV connection of additional equipment such as a camera.
Beovision 7 with DVD has the AV4 socket occupied by the DVD.
Speaker.
Connecting speakers is made in the Power Link sockets.
 Speakers is connected to the Power Link sockets as single or
pair. If pair a Power Link splitter is required.
  In TV the centre speaker is connected to the (centre) socket.
If extra centre speaker is to be connected, a Power Link splitter is required.
Selecting option on the TV-set
Option programming with Beo5:
Option programming is made with the Beo5 Configuration Tool.
Options settings are sent to the products by means of the Setup menu in Beo5
Option: OPTION 1 (Factory setting), with Beo4
                Press:                          | Display:
                STANDBY + LIST at the same time | OPTION?
                GO                              | V.OPT
                1                               | Observe confirmation
                                                | from BeoVision
It is not possible to connect an extra plasma screen to the TV.
********************* REMOTE CONTROL FOR MAIN ROOM ********************
The recommended remote control is Beo5
The following remote controls may also be used:
Beo4
 Setup for Beo5 remote control:
Programming Beo5 to operate products, Option programming and
zones, is done with the Beo5 Configuration Tool.
*************************** LINK SYSTEM SETUP *************************
Master Link
BeoVision 7 - 32"
Connection
The Aerial signal is distribuated to the TV in the Link Room from a
RF Link Amplifier.
Type 4052 Frequency range: 40 - 860 MHz
Part No.: 1405266.
Type 4053 Frequency rage: 5 - 65 MHZ / 87 - 860 MHz
With return path. The return path is intended for Set-top Boxes which
have return communication with the distributor of the programmes
for instance pay-per-view.
Part No.: 1405366.
If connection of more than three video link rooms is required,
RF shielded splitters with maximum two outputs can be used.
Alternatively an additional RF Link Amplifier may be used.
Connect the Master Link cable to the Master Link socket of the Video
Master in the central room.
of the Link TV.
Setting of option in the Link room
BeoVision:
  OPTION 6, with Beo4
         Press:                          | Display:
         GO                              | V.OPT
         6                               | Observe confirmation
                                         | from the BeoVision
Note!
The audio master in the main room cannot distribute PC sources, e.g.
N.MUSIC and N.RADIO to the Master Link system.
The PC sources are therefore only local sources in this Link room
********************* REMOTE CONTROL FOR LINK ROOM ********************
The recommended remote control is Beo4
Setup for Beo4 remote controle:
Beo4's "LIST" must contain the following items to be able
to operate the products from the Link Room.
LINK
AV      (only with S/W 4.0 or higher in Beo4)
See Beo4's operation manual page 10/12 on REMOVE and ADD functions
from/to the List
Master Link
BeoVision 6_26MKII
Connection
RF Link Amplifier.
Part No.: 1405266.
Part No.: 1405366.
of the Link TV.
BeoVision:
  OPTION 6, with Beo4
         Press:                          | Display:
         GO                              | V.OPT
Note!
If a mains power supply failure or switch off occurs,
the BeoVision may loose its option 6.
An introduction of a Master Link junction box in the Master Link system
can prevent this.
It is possible to connect a PC to BeoVision with good results, but some requirements
must be fulfilled: The PC must have a DVI-D or DVI-I connector. It will not be
possible to connect a PC via VGA connectors.
Important: It is very important that the computer and the BeoVision is turned off
while connecting the two products. If not there is a big risk that the display
adapter module (graphic card) in the PC will be damaged.
BeoVision supports 3 formats:
 480 x 640
 800 x 600
1280 x 720 (recommended)
If your craphic card does not supports 1280 x 720 we recommend use of
PowerStrip (http://www.entechtaiwan.net/ps.htm).
 PC on Beo 4 must be activated to get PC picture on BeoVision.
BeoVision with PC picture: N.Music operated on PC direct = sound and picture
on BeoVision.
N.Music operated on BEO 4. BeoVision will act as audio monitor (no picture), as this
functionality is the same as if BV 6 were placed in any other room.
Also please note that settings such as brilliance, contrast etc. must be done
in the PC and not on the BeoVision itself.
Operation: Simply choose "PC" in the Beo4 list and press "Go". If "PC" is not
present in the "List" you have to add it.
LINK
from/to the List
