ok cool. thanks.
i just looked into getting a new fuse... apparently mine is "slow"... i can get one that is "fast"... will this make a difference or should i look for a slow fuse?
i may have misunderstood the Canal St electronics guys... but does this sound right? basically, my filament is thicker than the ones i have found for sale.
thanks for all your help so far everyone! (especially since i didnt take the foil advice :D )
