Hi folks,
I just bought a Beocenter 9500 from fleamarket including Beolink 1000 remote control. Everything seems to work just fine except cd player, which does not read cd's at all. Lid opens and disk rolls fine but soon lid opens again. I tried to clean the laserhead, but it didn't help.
After quick check from user's manual I noticed that there is two screws under cd player which are supposed to be at "transport" holes when system is moved but those were at "play" holes when i bought it. So most likely moving system without locking cd has caused this malfunction? Is there any easy fix for this problem or should I contact my local B&O service?
Anyway, I think that 100 euros for beocenter and remotecontroller was still bargain.
Thanks, for your help,
Mikkis
