Yes there will appear to be pressure on the CD mechanism from the door. This is quite normal.
There are several possible reasons for your problem.
Dirty or incompatible cd's, bad capacitors on the cd servo board, faulty laser are but three possibilities. Assuming that you have played these cd's before with no problems then we are now coming down to solutions which require the attention of a service tech or similar type of person.
Where are you situated?
