Latest post 01-12-2009 12:13 PM by PL212. 6 replies.
Page 1 of 1 (7 items)
  • 01-02-2009 5:22 PM
    • Tower
    • Not Ranked
    • Joined on 01-02-2009
    • Posts 4
    beocenter 9300 CD player
    I have a used 18 year old Beocenter 9300 which has a problem with the CD player: when activated, the CDs either spin mercilessly or screech to a halt and the cover opens without playing the CD.  Anyone else have this problem and can you direct me toward a repair solution or if there is one?  jo
  • 01-02-2009 6:09 PM In reply to
    Re: beocenter 9300 CD player
    Probably dirty laser lens by the sound of the symptoms.
    Take a cotton wool bud and try gently cleaning the lens with a circular motion. Don't press too hard!
    Ideally the bud would be damped in isopropanol but as you are unlikely to have any a dry one will have to do.
    Try the CD again. Let us know what happens
    Regards Graham
  • 01-03-2009 11:00 AM In reply to
    • Tower
    • Not Ranked
    • Posts 4
    Thanks Graham.  I'm off to buy isopropanol.
     jo
  • 01-04-2009 10:46 AM In reply to
    • Tower
    • Not Ranked
    • Posts 4
    Graham - the lens cleaning did not work.  I do notice that when the CD cover closes over the cds the cover appears to be pushing down on the cd unit.  Is this common or is there perhaps an alignment issue?
    Jo
  • 01-04-2009 1:10 PM In reply to
    Yes there will appear to be pressure on the CD mechanism from the door. This is quite normal.
    There are several possible reasons for your problem.
    Dirty or incompatible cd's, bad capacitors on the cd servo board, faulty laser are but three possibilities. Assuming that you have played these cd's before with no problems then we are now coming down to solutions which require the attention of a service tech or similar type of person.
    Where are you situated?
    Regards Graham
  • 01-05-2009 8:14 PM In reply to
    • Tower
    • Not Ranked
    • Posts 4
    I'm in Cincinnati, OH
  • 01-12-2009 12:13 PM In reply to
    • PL212
    • Top 200 Contributor
    • Joined on 02-14-2007
    • Moderator - Seattle
    • Posts 318
    There ought to be a service center somewhere in Ohio that can help you out. If you can't locate one, contact "Atlantic Systems" (google them for their website) who are on the east coast but very good.
