Latest post 05-23-2007 7:47 AM by Thomas. 6 replies.
Page 1 of 1 (7 items)
  • 05-22-2007 6:36 AM
    • Thomas
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Norway
    • Posts 85
    AVANT DVD to feed Projector
    As far as I know the best video signal to get out of an Avant DVD is a S-video signal from the AV - Scart. Anyone know of a way to get i higher quality (I.e. RGB / Component) signal from the Avant DVD to a projector ?
    Br
    Thomas
    7-40 Mk3, Beo5/Beo4, Avant32DVD, BS3K, PentaIII, BL4K, BL Active w/BL2500, Avant28CTV,Beoport, AppleTV, 2xBC6K
  • 05-22-2007 1:36 PM In reply to
    Re: AVANT DVD to feed Projector
    Thomas,
    There is RGB in the SCART on the AVANT which will provide the best quality for your projector
    Regards Keith....
  • 05-22-2007 7:32 PM In reply to
    • cozza
    • Joined on 04-18-2007
    • New Zealand
    • Posts 119
    I was under the impression that the Avant only has RGB inputs on the scart connections. How do you reverse them and make them into outputs?
  • 05-23-2007 1:56 AM In reply to
    The AV and Decoder SCART's are RGB in only, but the AVANT DVD still has the Video Tape SCART which does have in/out as per the spec below
    Avant spec
    Regards Keith....
  • 05-23-2007 3:02 AM In reply to
    In the Avant menu, activate the scart plug as a non-BO VTAPE
  • 05-23-2007 3:04 AM In reply to
    • cozza
    • New Zealand
    • Posts 119
    Hi Keith,
    From the specs, the VTAPE scart appears to have composite video input and output, and RGB input only.
  • 05-23-2007 7:47 AM In reply to
    • Thomas
    • Norway
    • Posts 85
    HI all,
    I am also under the impression that it is only RGB inputs on the Avant, but nothing would please me more I there is an RGB out signal avaliable one one of the scarts.  Anyone that can confirm if this is so ?
    Thomas
