Peter/Anyone!
I'm having problems with a STB-C attached to Beovision 8 and (Amstrad?) Sky+ box.
The installation is new and I've already had the shop back once since the installation to get the STB-C working. Initially there was very erratic and poor response to the Beo4. This problem was thought to be that the IR emitter was too strong! Indeed placing a piece of paper between the emitter and the sky IR receiver has worked very effectively in getting the system to perfectly respond to up/down arrows and the numerical part of the Beo4 keypad.
However, none of the central buttons (FF, RWD etc) appear to work. Additionally 'Go' doesn't appear to act as 'Select', but instead goes straight to playing the last programme recorded. I'm also unsure how to Record a programme - Record on the Beo4 doesn't seem to do anything.
I'm loathe to call the shop out again without checking I'm not being an idiot and misunderstanding how to correctly operate the system.
Thanks in advance for any helpful suggestions.
AP
