Just bought an Avany 32 VCR of ebay to replace my dead LS5500 ( previous post) it has an STB which has the old firmware and will req an updated eprom.
It doesn't have an IR cable, will any IR blaster cable with a 3.5mm jack do the trick ( like this one on ebay
270319119928 )
Also by installing the IR cable will it enable to use the remote control ( with the digi boxes own remote) with the box hid behind , or is it all tied in to the STB ?
Cheers
Steve
