Hi and welcome to the forum!
Yes, there are several options:-
1) If you have a separate pre-amp and power amp, then it is easy - just remove the power amplifier and connect the Beolab speakers directly to the RCA sockets marked "pre-out" on the pre-amp. Set the speakers to "Line" using the switches underneath and use the RCA input sockets..
2) If you have an integrated amplifier without volume-controlled line level outputs (pre-outs), the easiest way is to get a pair of attenuated speaker cables (ask LifeStyleAV, IconicAV or MoreThanAV, they are all able to obtain these cables) to reduce the amplified outputs from your amplifier down to suitable levels to connect to the Beolab speakers. Again, set the speakers to "Line" mode and use the RCA sockets to connect them.
For reference, -20dB attenuated cables are normally suitable for most power amplifiers producing between 20W and 100W into 8Ohms, for connection to Beolab speakers.
Best regards,
Steve.
PS. Please DO NOT try to connect your Beolab speakers directly to the speaker outputs of a conventional power amplifier using normal speaker cables - this will be likely to cause serious and very expensive problems to your speakers!
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
