Latest post 12-30-2008 7:03 AM by tournedos. 14 replies.
Page 1 of 1 (15 items)
  • 12-13-2008 12:15 PM
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    Beo 4 Damage Limitation or User Manual?
    Does anyone know how to correct a BEO4 remote (after an accident!) from reading VMEM when almost any buttons are pressed.  I have cleaned (carefully!) the rubber buttons and also wiped the board.  The dome foil buttons appear to be sealed so I do not believe that any moisture is causing a problem there.
    I have a workshop manual for the Beolink 1000 but only a user guide for the BEO4.  Is there a BEO4 User Manual?
    Any thoughts welcomed.
    Brian
  • 12-27-2008 6:16 AM In reply to
    • Xseries
    • Hampshire
    • Posts 433
    Re: Beo 4 Workshop or User Manual?
    Have workshop manuals stopped being produced (re request for BEO4 manual)  since most items are now replace board or throw away rather than repair???
    BrianUnsure
  • 12-27-2008 6:45 AM In reply to
    Been digging around - remote manuals sometimes are included in other product service sheets. However nothing doing. I think you may be right. Sad
  • 12-29-2008 5:50 AM In reply to
    Re: Beo 4 Damage Limitation or User Manual?
    Have you tried removing the metal spring holding the dome foil and cleaning the contacts underneath?
    Marcus
  • 12-29-2008 12:46 PM In reply to
    Xseries:
    Brian
    A user guide is supplied with each Beo4. If a user manual is different to the user guide then I haven't seen one.
    A service manual for the Beo4 does exist and I have one!
    I am willing to send it to Peter for scanning for the site, please don't dismantle it.Smile
    Regards Graham
  • 12-29-2008 5:56 PM In reply to
    • Xseries
    • Hampshire
    • Posts 433
    Thank you for the offer of a Workshop Manual for a BEO4 - I hope Peter will take it up!
    Do you have one for an MCP 5500 or 6500 by any remote possibility (pardon the pun!) ?
    I have in fact repaired said BEO4 - a new dome foil (as suggested by Andy T) did the trick.  I will try cleaning the old foil and see if it can be resurrected.
    Brian
  • 12-29-2008 6:15 PM In reply to
    Xseries:
    The MCP5500/6500 is handled in the service manual for Beomaster 6500 (I don't know if there's a more thorough manual for it separately ).
    I would've told you this yesterday in the Wanted section, but my stars have been prematurely robbed from me Super Angry
    -mika
  • 12-29-2008 7:34 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Ooh Mika!  Did you have an  f  as well?
    Poor me, never win owt!
  • 12-30-2008 3:12 AM In reply to
    No, I'm not that old Laughing
    I'm couple of months short, though - I thought starting this thread would've been enough, but now I've sent the email as well. No problem at this point, for some peculiar reason I can still download the manuals, which is all I'll need for some weeks... Wink
    -mika
  • 12-30-2008 4:41 AM In reply to
    Edited due to "*** up"
    Regards Graham
    Xseries:
    Sorry no
    Regards Graham
  • 12-30-2008 5:46 AM In reply to
    • Xseries
    • Hampshire
    • Posts 433
    I have looked at the BM 6500 manual at the download site,  but sadly it appears to be missing the final few pages.Sad
    There is a breakdown of the parts in an MCP but nothing more.Smile
    Brian
  • 12-30-2008 6:31 AM In reply to
    Xseries:
    Well, the schematic is on page 2-6, PCB pictures on 2-7,  display survey and IC pinouts on 2-8, and finally the mechanical breakout and parts list on 4-3. Page 4-4 is already handling the system stand. I don't think anything is missing - it's just already going to the later route and the "official" service is not supposed to do much on component level, just replace modules... this usually happens when the bulk of the circuit is surface mount, like in the MCP. An adventurous engineer can still repair them, but it may not be cost effective any more at the hourly rates an official service is supposed to charge.
    I see there's a test point jumper designated as  "display on". It might do the job some people have asked for, namely keep the display on at all times and drain the batteries really fast Smile
    -mika
  • 12-30-2008 6:44 AM In reply to
    • Xseries
    • Hampshire
    • Posts 433
    Thank you for that - I had skimmed the pages and was looking for sections 7, 8 and 9 that the contents on page suggest should cover "repair hints" "Insulation test" and "final test".
  • 12-30-2008 7:03 AM In reply to
    I took another look, and on page 5-1 there are two adjustments for the MCP - the power supply voltage and the volume control pulse amplitude. I'm afraid that's all there is to be found...
    -mika
