A Masterlink to a Beolab2000 from a Beovison7 LCD TV in THE SAME ROOM gives an unacceptable echo.
My dealer has explained that the audio of a LCD TV has an internal delay. This is caused due to the necessary build up of the video. The audio signal to the Masterlink does not have this delay and gives an echo to the Beolab2000 in the same room.
In my opinion this is a not acceptable design mistaken of the LCD TV by B&O. Why is the audio signal to the Masterlink not equipped with the same delay?
The forum at www.bang-olufsen.com gives a solution: I also have echo when I played radio on both BV7 and BS9000 . However, these were adjusted by going into the service menu on BV7 and adjust the setting for sound delay. Now everything works fine. I changed the settings in the service menu, after conference with my dealer.
In the settings of the BV7 I could not found this. Have other B&O users the same problem?
