Hi Peter,
The only connections on the CDX are 2 RCA cables. I have a special order DIN to RCA connector which allows to connect the CDX to my 2400. I did have the DIN connected to the Tape socket. The several times I tried playing it, I got heavy static. MIRACLES DO HAPPEN. After reading your response, I hooked the CDX up to an NAD reciever and got the same static sound. I pressed Pause which stopped the music, but allowed the CD to continue spinning. Out of the clear blue, 5 seconds of the same static sound appeared and then went away. I pressed Play again, and low and behold, clean, clear music came out of the speakers! I've been playing it for about half an hour now, and it works and sounds fantastic!!! I'm almost afraid to turn it off now!
Thanks for your concerned and timely response,
Aaron
