Latest post 12-03-2008 9:25 PM by jk1002. 6 replies.
Page 1 of 1 (7 items)
  • 12-01-2008 1:28 PM
    • Beogen
    • Top 500 Contributor
    • Joined on 05-12-2007
    • Belgium
    • Posts 135
    How to rip a gapless live CD
    Hello,
    I'm using a Beomedia as a digital player and I have tried to rip in MP3, WMA and AAC format using WMP, Beoplayer, EAC and Itunes.
    I keep on having small gaps in between the tracks of the live CD's. Can I avoid this or do I have to get used to the idea that the BM1 is not capable of producing gapless music.
  • 12-02-2008 5:14 PM In reply to
    Re: How to rip a gapless live CD
    Hi there....
     I've had the same problem when using Beosound 2. It drove me crazy and I looked for a solution everywhere. I bought an Ipod touch.
     Beosound 3200 has the same issue, the main reason I just wouldn't buy one.
     Regards...
    I wish I was the person my dog thinks I am.
  • 12-03-2008 1:10 PM In reply to
    • Beogen
    • Belgium
    • Posts 135
    Hello sprocket,
    I'm 'glad' I'm not the only one because I started to think I used the wrong programs. I also think it's a shame that B&O is unable to come up with a proper solution.
    In another topic I asked the question if BM1 will get a new SW release, similar to the BM5. Maybe then the problem will be solved. I got no replies...
  • 12-03-2008 1:15 PM In reply to
    Itunes actually can rip without gaps, however you have to use the aac format.
     Its not a thng that you can fix in the software, its a problem with the MP3 file format. Everyne who is using MP3 in their music player will have this problem.
    Cheers
    JK
  • 12-03-2008 1:36 PM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    jk1002:
    Cheers
    JK
    I believe iTunes has supported gapless MP3's since version 7.
  • 12-03-2008 4:04 PM In reply to
    • Beogen
    • Belgium
    • Posts 135
    I used the Itunes AAC ripper on one of my tests and playback was on BM which supports the AAC format, still I had this problem. So I can assume that the BM doesn't handle the AAC format like it should be.
  • 12-03-2008 9:25 PM In reply to
    http://en.wikipedia.org/wiki/Gapless_playback
    correct, it works for mp3 too. i didnt know that. the wki is explaining the issue, the gap sits apparently in teh MP3, however there is a tag that contains the lenght so that it can be removed.
