You can connect all your products via Masterlink without problems.
Depending on the location of the products, the Masterlink can be wired in "daisychain" or "star" configuration or a mixture of both whether using pre-wired plugin distribution boxes or manually wiring the connections in junction boxes. Depending on your cable runs you will need several connection boxes
Several types of Masterlink connecting boxes are shown below
