Latest post 12-02-2008 9:42 AM by mjmedlo. 4 replies.
Page 1 of 1 (5 items)
  • 12-01-2008 12:59 PM
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    Masterlink Connections
    Does anyone know if there are a max number of Link products you can run from one system?
    I'd like to connect the following
    BS9k
    BC2
    BS4
    BL3500
    BL Passive
    BL3500
    BV9
    BL2000
    I know the distributors are only 6 slots. . .do I have a problem or can I just get another distribution box?
    MJM
    I'm ready for something new that I actually want to buy!
  • 12-01-2008 1:11 PM In reply to
    Re: Masterlink Connections
    max is (16) including master room for (1) network.
    max cable length is 1320ft.
    • B&o bottle opener
  • 12-01-2008 1:43 PM In reply to
    You can have several boxes.
  • 12-01-2008 3:51 PM In reply to
    You can connect all your products via Masterlink without problems.
    Depending on the location of the products, the Masterlink can be wired in "daisychain" or "star" configuration or a mixture of both whether using pre-wired plugin distribution boxes or manually wiring the connections in junction boxes. Depending on your cable runs you will need several connection boxes
    Several types of Masterlink connecting boxes are shown below
    Regards Keith....
  • 12-02-2008 9:42 AM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    Thank you all. . .My bulk roll of ML arrives today along with a couple distributor boxes and some punch down junction boxes
    Wish me Luck
    MJM
