1st March February 2012
05-19-2007 1:11 PM
elephant
- Joined on 04-16-2007
- Melbourne, Australia
- Posts 2,215
Hi, I am trialing some powerlink speakers into my Beoport. Got them (BL4s) home and was caught by a lack of daisy chaining on the BeoLab 4s and/or the lack of two power link outputs on the Beoport. So I test listened to just one speaker ... beautiful clear sound, much better than out of the masked off mini-jack output port. Then I dashed back to the store to get a power link Y-splitter and connected it all. *shock* I now have speaker hum ... I know that the power link cables need to be Mk-IIIs so I presume the hum is coming from the fact that the Y-splitter is down level in power link status. Do you all agree with my diagnosis ? [:'(]
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
Keith Saunders
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
How old is your Beoport ? The reason I ask is because there is an issue which can be quickly fixed with an earth link on the powerlink of the Beoport. Keith..
Keith Saunders
- Posts 3,810
Further to my last post, if you have an early PC2/Beoport then Pin 7 (data ground) has no connection to BeoPort/BeoLink PC2.
You can solve the problem by
Short-circuit pin 2 and 7
Alternatively, this modification can be made in the splitter connected to BeoPort
Keith..
Santiago
- Switzerland
- Posts 3,286
I remember very well when I bought the BL4s for my beoport, that my dealer had 2 different models of powerlink Y-spliters in the store, and then he said me that one of them didn't worked well with the BL4s/BL3s (hum noise), but the other one (which he verified very carefully) worked fine. So maybe your problem is there. I hope that helps you, best regards.
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Peter: The only thing about this is the fact that attaching one gave no hum. Would suggest, just as Ed supposes , that the fault is in the Y splitter.
Wakey wakey Peter. That wasn't Ed. Are you burning the candle at both ends? Perhaps you should see a doctor Andy T.
Santiago
- Switzerland
- Posts 3,286
I'm sorry, but a parallel question: I'll receive soon a brand new Beolink active for the bedroom, How many powerlink outputs has the Beolink active; only one, same as Beoport? So if I want connect BL4s or BL3s to this Beolink active do I need this same Y-splitter? Thanks in advance
Jandyt
- Posts 13,004
Santiago
- Switzerland
- Posts 3,286
I'm sorry again, I've already found the answer:
I've just download the "beolink active reference" manual and there I can see it has 2 powerlink sockets...so no splitter needed. My fault asking so quick before thinking... just tired.
elephant
- Posts 2,215
Peter
"Tha' would be grand" mainly to introduce you to Sue !
Address in PM And just to complicate things, when I removed the Y-splitter the hum lessened but did not disappear (mind you I hand also shuffled power cables around) ... supposedly my Beoport is relatively new ... as in maybe 12-18 months old ... but I dont know how long it was on the shelf in Australia :(
elephant
- Posts 2,215
Never got anywhere with the powerlink, so I bought an old fashioned jackplug splitter and cables ... I tried the jackplug from the masked OUTPUT port at the back of the Beoport and that had hum ... not as bad as the powerlink though I then moved the jackplug directly to my PC bypassing the Beoport ... no hum! Looks like I do have an old Beoport although I don't understand why I did not hear the hum when I only had the one speaker going .................
Page 1 of 1 (15 items)
