Latest post 05-21-2007 2:01 AM by Keith Saunders. 14 replies.
Page 1 of 1 (15 items)
  • 05-19-2007 1:11 PM
    Power Link adapter
    I am trialing some powerlink speakers into my Beoport.
    Got them (BL4s) home and was caught by a lack of daisy chaining on the BeoLab 4s and/or the lack of two power link outputs on the Beoport.
    So I test listened to just one speaker ... beautiful clear sound, much better than out of the masked off mini-jack output port.
    Then I dashed back to the store to get a power link Y-splitter and connected it all.
    *shock*
    I now have speaker hum ...
    I know that the power link cables need to be Mk-IIIs so I presume the hum is coming from the fact that the Y-splitter is down level in power link status.
    Do you all agree with my diagnosis ?
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 05-19-2007 1:25 PM In reply to
    Re: Power Link adapter
    How old is your Beoport ?
    The reason I ask is because there is an issue which can be quickly fixed with an earth link on the powerlink of the Beoport.
    Keith..
    Regards Keith....
  • 05-19-2007 1:30 PM In reply to
    Would seem very sensible, except I have Beolab 3s coming off my Beoport (Beolink PC2) using a Y connector and no hum at all. I did initially, but changed the Beolink PC2 for a newer one and the hum went. Make sure all the plugs and sockets are well seated.
  • 05-19-2007 1:31 PM In reply to
    Further to my last post, if you have an early PC2/Beoport then Pin 7 (data ground) has no connection to BeoPort/BeoLink PC2.
    You can solve the problem by
    Short-circuit pin 2 and 7
    Alternatively, this modification can be made in the splitter connected to BeoPort
    Keith..
    Regards Keith....
  • 05-19-2007 1:57 PM In reply to
    The only thing about this is the fact that attaching one gave no hum. Would suggest, just as Ed supposes , that the fault is in the Y splitter.
  • 05-19-2007 2:22 PM In reply to
    I remember very well when I bought the BL4s for my beoport, that my dealer had 2 different models of powerlink Y-spliters in the store, and then he said me that one of them didn't worked well with the BL4s/BL3s (hum noise), but the other one (which he verified very carefully) worked fine. So maybe your problem is there.
    I hope that helps you, best regards.
    Santiago
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Peter:
    Wakey wakey Peter. That wasn't Ed. Are you burning the candle at both ends?
    Perhaps you should see a doctorWink
    Andy T.
    Poor me, never win owt!
  • 05-19-2007 2:47 PM In reply to
    Elephant is another Edward! And a fine man - and a resident Geordie! Sort of! Laughing
    Would you like to try my splitter to see if that is the problem? I have an early morning assignment but could drop by later!
  • 05-19-2007 2:53 PM In reply to
    I'm sorry, but a parallel question:
    I'll receive soon a brand new Beolink active for the bedroom,
    How many powerlink outputs has the Beolink active; only one, same as Beoport?
    So if I want connect BL4s or BL3s to this Beolink active do I need this same Y-splitter?
    Thanks in advance
    Santiago
  • 05-19-2007 2:59 PM In reply to
    • Jandyt
    • Posts 13,004
    EmbarrassedEmbarrassed
  • 05-19-2007 3:09 PM In reply to
    Embarrassed I'm sorry again, I've already found the answer:
    I've just download the "beolink active reference" manual and there I can see it has 2 powerlink sockets...so no splitter needed.
    My fault asking so quick before thinking... just tired.
    Santiago
  • 05-19-2007 5:17 PM In reply to
    Peter
    "Tha' would be grand" mainly to introduce you to Sue !
    Address in PM
    And just to complicate things, when I removed the Y-splitter the hum lessened but did not disappear (mind you I hand also shuffled power cables around) ... supposedly my Beoport is relatively new ... as in maybe 12-18 months old ... but I dont know how long it was on the shelf in Australia :(
  • 05-20-2007 11:27 PM In reply to
    Never got anywhere with the powerlink, so I bought an old fashioned jackplug splitter and cables ...
    I tried the jackplug from the masked OUTPUT port at the back of the Beoport and that had hum ... not as bad as the powerlink though
    I then moved the jackplug directly to my PC bypassing the Beoport ... no hum!
    Looks like I do have an old Beoport although I don't understand why I did not hear the hum when I only had the one speaker going .................
  • 05-21-2007 1:54 AM In reply to
    Sorry I didn't get to you - bit tied up this week end but it sounds as if you have identified the problem. There is a simple fix which is to short pin 2 and 7 which is all that the new ones do, as Keith has pointed out.
  • 05-21-2007 2:01 AM In reply to
    Just because you did not hear the hum when you only had one speaker connected does not mean that the Beoport is not at fault in my view.
    I suggest you do a test and with the power switched off your Beoport and the powerlink cable removed, check with a multi-meter to see if pins 2 & 7 of the Powerlink on the Beoport are shorted together. If they are not, then just short them together.
    Regards Keith....
