I am trying to set something up for a friend and hopeful you guys can help.
He has an existing B+O multiroom system all ML'd. Within the drawing room is an Avant with 8000's plugged in. In an adjacent room, but still ML'd is a 9000 amongst others.
He is replacing the avant with the Loewe Indi 52". Speaker wise within the drawing room, this will use the line level input on the 8000's but can i somehow utilise something like the active kit and an IR sensor to link the 9000 in AND retain control of the 9000 through the ML system? I have seen people do this before but never had the need to investigate.
Centre channel will be provided by either the Loewe centre speaker or a BeoLab 10 again on a line level.
I have suggested he gets the BV9 but there is no way he will spend that much at the moment.
Any help much appreciated from a long time observer, first time poster.
