Hi all
the glass panel on one of my mx's has come off leaving the (steel) mounting strips in situ - what can i use to 'restick' it back on - do i need to remove the strips or just lay the tv on its back well propped and lay the panel back on whatever adhesive with a little extra weight over the aforesaid strips to ensure bonding
I thought of epoxy or industrial double sided tape!
Someone out there must have had similar probs - all suggestions greatfully received
tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
