Latest post 11-29-2008 3:08 AM by stotty1111. 4 replies.
Page 1 of 1 (5 items)
  • 11-28-2008 4:50 AM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    MX **** glass panel probs
    Hi all
    the glass panel on one of my mx's has come off leaving the (steel) mounting strips in situ - what can i use to 'restick' it back on - do i need to remove the strips or just lay the tv on its back well propped and lay the panel back on whatever adhesive with a little extra weight over the aforesaid strips to ensure bonding
    I thought of epoxy or industrial double sided tape!
    Someone out there must have had similar probs - all suggestions greatfully received
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 11-28-2008 5:00 AM In reply to
    Re: MX **** glass panel probs
    From what I know you should never put a CRT TV on it's back.
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 11-28-2008 7:44 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Tony, I would try using Silicon sealer. This seems very good as a glue IMO, used it a few time myself on different things. Although never on an MX contrast screen.
    CraigSmile
  • 11-28-2008 10:11 AM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    Our esteemed TV expert Nobby uses epoxy resin for this. Don't use the "fast setting" stuff, it is rubbish.
    Chris.
  • 11-29-2008 3:08 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Thanks guys
    have used tape in this instance (industrial grade) - up to now is working - however when time allows i will probably go with the araldite route
    nb the tv has a pillow under it just in case(the panel falls out)
    t
