Hello Craig, there is a l no inside that reads T2922 i think that is the correct one.
The prob has been there for quite a while and i have recently decided to set the system up again, so i thought i should try and repair this.
Even before the tape deck wasnt used a great deal.
Thank you for your help,
Andrew.
