Latest post 11-22-2008 4:20 PM by Craig. 5 replies.
Page 1 of 1 (6 items)
  • 11-21-2008 10:44 AM
    beacord drive belt prob
    Hi, i have a problem with the large belt it has came off does anyone have a diaggram on how to replace it or instructions on how to fix it?
     I would be most gratefull for any help on this.
    Thx Andrew Galloway
  • 11-21-2008 11:56 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: beacord drive belt prob
    Hello Andrew and welcome to Beoworld. Which model Beocord is it? If the large belt has come of then it may have stretched with age. Stripped down one that had done this myself only last night.
    CraigSmile
  • 11-22-2008 6:48 AM In reply to
    Hello Craig,    there is a l no inside that reads T2922 i think that is the correct one.
    The prob has been there for quite a while and i have recently decided to set the system up again, so i thought i should try and repair this.
    Even before the tape deck wasnt used a great deal.
    Thank you for your help,
    Andrew.
  • 11-22-2008 8:35 AM In reply to
    • Craig
    • Posts 4,855
    That is a Beocord 2000, and I would guess the belt has stretched. Every one I have had has had the same problem. One of our members Martin (Dillen) can supply the belts for these. Drop him a PM and he will give you a price and how to pay. Should take about 10-15 mins to fix.
    CraigSmile
  • 11-22-2008 12:34 PM In reply to
    Thx Craig will contact Martin as soon as poss.
    Thx for the welcome and the help,
    Andrew
  • 11-22-2008 4:20 PM In reply to
    • Craig
    • Posts 4,855
    No problem Andrew, thats what Beoworlds for.Smile
    CraigSmile
