Latest post 09-26-2010 10:38 AM by mpijl. 2 replies.
Page 1 of 1 (3 items)
  • 11-19-2008 5:24 PM
    • mpijl
    • Not Ranked
    • Joined on 11-19-2008
    • Posts 15
    • Gold Member
    Guide at Samsung H360R
    The beo5 (latest firmware & software) works fine with the Samsung H360 connected to BV7-32, except for the guide "button". Nothing happens.
    Anybody having the same problem and/or knows a solution (manually reprogramming IR codes?)?
    Filed under:
  • 11-29-2008 6:25 AM In reply to
    Re: Guide at Samsung H360R
    You have to reprogram the guide button manualy. You dan get the guide whit go 9. the beo 5 adres must be dtv i think. If it don't work send me an pm and i take a look in mij own beo5. It works fine here
  • 09-26-2010 10:38 AM In reply to
    • mpijl
    • Not Ranked
    • Posts 15
    • Gold Member
    Following up an old lead.
    Apparently in the configuration software there is only the name 9, but not the actual code for 9. Changing the IR-code to CIFFER-9 makes it happen.
