Just a note if your using the PopcornHour codes i created, Make sure you leave the 'buttons' in the 'touch' screen part of the remote, It will take up 5 pages but you can then assign the commands to the 'hard' keys.
I made the mistake of deleting them once i had assigned them to the hard keys only to find that it looses the command if they're deleted.
unfortunatly as this is a 3rd party set of ir codes you will have to have line of sight.
