Latest post 12-16-2008 5:56 PM by halid. 13 replies.
Page 1 of 1 (14 items)
  • 11-16-2008 5:11 AM
    Similar IR-codes for the Popcorn Hour ?
    Hi, I posted a thread a while ago concerning my mediaplayer Popcorn Hour that I would like to control with my B&O-remote. The Popcorn is not yet added to the PUC-list but I found some interesting information regarding which IR-codes the Popcorn uses. If you follow the link, does someone have a clue if I can use some other device from the PUC-list that uses the same codes as the Popcorn ??
     http://support.popcornhour.com/article.aspx?id=1005
     Best regards
     Hans, Sweden
  • 11-16-2008 6:13 AM In reply to
    Re: Similar IR-codes for the Popcorn Hour ?
    If you use Beo5, maybe Keith can make it work directley from Beo5
    I know Beo5 can handle NEC
  • 11-16-2008 1:27 PM In reply to
    I have a Beo5 so it would be really nice. Is it possible that you can help me Keith ?
    Best regards
    Hans
  • 11-16-2008 1:32 PM In reply to
    halid:
    Best regards
    Hans
    maybe you can use this and give them to Keith
    PM him and ask
    this is for A-100
    768032211104151000000ANGLE
    768032211088167000000AUDIO
    768032211080175000000DOWN
    768032211064191000000ENTER
    768032211176079000000FWD
    768032211144111000000HOME
    768032211194061000000LEFT
    768032211202053000000MENU
    768032211136119000000NEXT
    768032211042213000000PAUSE
    768032211010245000000PLAY
    768032211082173000000POWER
    768032211072183000000PREV
    768032211234021000000REPEAT
    768032211226029000000RETURN
    768032211112143000000REV
    768032211128127000000RIGHT
    768032211168087000000SLOW
    768032211050205000000STOP
    768032211026229000000SUBTITLE
    768032211218037000000TIME SEEK
    768032211242013000000TITLE
    768032211096159000000UP
    768032211152103000000ZOOM
  • 11-25-2008 6:21 AM In reply to
    How did you guys get on with this. Please let me know if you got anywhere.
    Thanks,
    Ash.
    Beosystem 3, Beosound 4, Beolab 9, Beolab 3, Beolab 8000
  • 11-26-2008 2:18 AM In reply to
    A Beo5 XML template for the Popcorn Hour A100/A110 is now available for download HERE
    Regards Keith....
  • 11-26-2008 4:26 AM In reply to
    Keith,
    You're a legend!! Thanks very much for your efforts!!
    Ash.
  • 11-26-2008 5:30 AM In reply to
    Cool, just a quick question, would it need to have a line of sight for the IR or could you se the STB-C on the TV to send the IR signal?
  • 12-07-2008 5:57 AM In reply to
    Many thanks Keith !!! Really impressed with your skills.
    Best regards
    Hans
  • 12-08-2008 1:57 AM In reply to
    Just wanted to tell that I downloaded yesterday and everything works like a dream. Thanks again Keith !
    Best regards
    Hans
  • 12-08-2008 2:18 AM In reply to
    Hans,
    I am very pleased that everything is working to your satisfaction and for your very kind feedback.
    Regards Keith....
  • 12-11-2008 4:42 PM In reply to
    Just a note if your using the PopcornHour codes i created, Make sure you leave the 'buttons' in the 'touch' screen part of the remote, It will take up 5 pages but you can then assign the commands to the 'hard' keys.
    I made the mistake of deleting them once i had assigned them to the hard keys only to find that it looses the command if they're deleted.
    unfortunatly as this is a 3rd party set of ir codes you will have to have line of sight.
  • 12-11-2008 4:44 PM In reply to
    oh and a quick thanks to keith, without his 3rd party xml generator i wouldnt have been able to create the popcornhour codes.Big Smile
  • 12-16-2008 5:56 PM In reply to
    Wtabram, thanks for your post. I also noticed the problem that you mention and could not make it work how matter I tried but came to the same conclusion as you did. You need to keep the "baseline" for the Popcorn, then you can assign the commands to other keys.
    Regards
    Hans
