Hello, and thanks for your reply.
Finally I checked the headphone jacks, ML,... but without luck.
I have a macbook that I use everyday at home and at work. When I arrive at home I connect the usb and headphone wires to beoport. I like very much to see the information on the BC2 display and also to control it from the BC2, but I have very problems... A lot of times, when I connect my macbook to beoport, the beolink system stops to work. I have to disconnect the power supply. Do you know what is the way for the system doesn't hang?
Since I have very problems with Mac-Beoport I use Airport Express (connected to A.Aux (BC2)). Then I press A.Aux and it just works perfect. My iPod Touch control the rest... Why do you connect the sound-out of airport express to beoport? The mac-beoport needs two wires: usb and minijack.
But I would like to control n.music (Beoport-mac) from BC2 without problems and feel the sound perfect... I'm very worried with this....
Another question:
Does the BM-Link sound menu work for you? I can't use it, doesn't work anyone.
This is the menu:
