I have just been given a 9500, and am trying to figure out how to connect speakers to it.
I have the manual, but all it says about is how to use the system, not how to set it up.
The model I have says it was made in 1986 if that makes a difference.
I already have some good speakers I was planning on using, I can't figure out how to hook them up.
Can anyone help?
thanks
Kevin
