1st March February 2012
Latest post 11-17-2008 4:00 PM by Beogen. 15 replies.
10-31-2008 4:19 PM
cjocc
- Joined on 09-07-2007
- Sweden
- Posts 39
If you'd buy a BS3 today, what Panasonic (or other) screen would you go for?
I've got an "offer you can't refuse": Buy a used Beosystem 3 from a dealer. But I have not the money to buy a BV 4 display. So here is my obvoius question, knowing it has been asked before but then when D8/9 displays where the only ones available: What Panasonic commersial screen would today be the best choice for 42 or 50" or other brand? Thanks cjocc
BC 2, MX7000, BeoPort, BLab 35000,BLab 3,BLab 8000,BeoC 6000, Beo4
Bieele
- Joined on 04-16-2007
- Netherlands
- Posts 339
Re: If you'd buy a BS3 today, what Panasonic (or other) screen would you go for?
How lucky can you be; an offer you can't refuse for a BS3! Hope I get an offer like that also! I think these screens would be good choices: TH-42PH10EK TH-42PF10EK TH-42PH9EK What do you intend to use as center speaker? Good luck! Bieele
Heej zuij der alles veur gaeve
En heej zaet ze mogen ut hebbe van meej
Movie
- Joined on 04-18-2007
- Posts 90
Is there a 50" full HD Panasonic that would be suitable, to use with Beosystem 3.
Bieele
- Netherlands
- Posts 339
Movie:Is there a 50" full HD Panasonic that would be suitable, to use with Beosystem 3.
I think that this should work: Panasonic TH-50PF10EK • 50 inch / 127cm Diagonaal • 10.000:1 Contrast
• Full High Definition 1080p Bieele
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
Think about that most non B&O (maybe all) plasma screens block the IR signal of the Beo remotes!
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
cjocc
- Sweden
- Posts 39
Bieele: How lucky can you be; an offer you can't refuse for a BS3! Hope I get an offer like that also! I think these screens would be good choices: TH-42PH10EK TH-42PF10EK TH-42PH9EK What do you intend to use as center speaker? Good luck! Bieele
Thanks Bieele, Been out travelling so hard times getting online. I'm thinking of using a 7-4 as center. I hope though the screens you mentioned including the 50" will work with the Beo4 as some has stated before, here in the forum, with other earlier models of Panasonic Anything else to consider/be aware of? /cjocc
cjocc
- Sweden
- Posts 39
M4SPM
- Burnley, Lancashire United Kingdom
- Posts 38
I have a TH42-PH9 and can confirm since Software updates this no longer works although it used to work. I also know someone who has a TH-50PF10EK and this does still work
Beogen
- Joined on 05-12-2007
- Belgium
- Posts 135
M4SPM:I have a TH42-PH9 and can confirm since Software updates this no longer works although it used to work. I also know someone who has a TH-50PF10EK and this does still work
I have the same screen and had the same problem. By tricking the BS3 (SW4.17) telling it's a BV4-50 D9 everything works as if it was a BV4. Also my dealer don't have the answer why I have to do this. Maybe because I use the original Panasonic DVI module. According to another forum member something has to be flashed in the Pana screen or DVI module in order to be seen as a true BV4. I would like to know more about this assumption. Don't forget to change the setting 'Monitor Auto Detect' to 'off'. Otherwise you run into problems.
M4SPM
- Posts 38
I have just set my settings to the same and my monitor now switches on and off fine. Thanks for that
kawo
- Joined on 04-17-2007
- Posts 516
I have a TH50-PH10 and it works fine even the current software. I only had to switch off the monitor auto detect (with the auto detect on the BS3 thinks it is a Full HD panel and sends the wrong signal) The G9 and G10 can not be changed to a BV4 as the old panels anymore, this could be done with the old pana screens acording to the service manual (see manual section on beoworld) Karsten
_________________________________________________________________________
BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
Movie
- Posts 90
Thanks Bieele Not all dealers stock Professional Displays, guess it would be easier to purchase from on line supplier. Movie
csmager
- Joined on 05-09-2008
- Posts 213
Thought I'd join in here instead of starting a new thread about this. I currently have a TH42PH10 in my system, and I'm thinking about swapping the Denon Receiver and Speakers with a BeoSystem 3 and assorted B&O Speakers. Do the dealers entertain the idea of connecting non-B&O screens, or will they not want to know? I'd expect the chance of making £5.5k on the sale of the BeoSystem 3 might persuade them to look into it, but are 3rd party screens 'supported' by B&O? It sounds from this thread that my existing screen would work, and turn on/off via the serial port. Is that the only thing it would do?
Beogen
- Belgium
- Posts 135
Autocontrast will also work, at least with generation 9
csmager
- Posts 213
How would auto contrast work without a light sensor? Or is there one in the BS3? Or is it changed irrespective of light level?
Beogen
- Belgium
- Posts 135
The light sensor is delivered together with the BS3. It's part of the IR sensor.
Page 1 of 1 (16 items)
