Latest post 10-21-2008 2:57 AM by Daniel. 14 replies.
Page 1 of 1 (15 items)
  • 10-18-2008 3:31 AM
    • Teaboy
    • Not Ranked
    • Joined on 10-18-2008
    • Posts 2
    What remote do I need for a B&O LX5500?
    I have an LX5500 TV and the remote has broken. I want to get another one but I'm unsure whether I should try and find the original remote or whether one of the newer B&O remotes will work with it.
    Any advice on which is the best route to take?
    Filed under: ,
  • 10-18-2008 3:52 AM In reply to
    Re: What remote do I need for a B&O LX5500?
    You should buy an original BeoLink 1000. Either used or new.
    BeoVision10-46MKII,BL3,BL2,BS8,Beo5
  • 10-18-2008 5:40 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    Any remote except  Beo1 will work. The original is Beolink 1000, but I now use a Beo4 with no problem. You can also use Beolink 5000, a two way remote (LX 5500 has two way ir control). Beolink 7000 will also work, but it would be overkill unless you don't also have a two way BeoCenter.
     I believe they all except 7000 is still available as new from B&O.
  • 10-18-2008 5:55 AM In reply to
    Dont buy a Beo4. If ever you have to program some of the stations its a lot more difficult to do it with a Beo4.
    A task that only takes seconds with BeoLink 1000.
  • 10-18-2008 9:04 AM In reply to
    I use a Beolink 1000 mk 3 with mine. I guess its the original one as it came with the Beovision.
    Mine was DOA so I went by the B&O shop and had a new printboard installed.
    It still works great to this day.
    I would sugest to either fix the one you got or find a direct replacement.
  • 10-18-2008 9:35 AM In reply to
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    BMGHB:
    I know, but since the death of analogue TV this is not a problem anylonger.
  • 10-18-2008 12:17 PM In reply to
    • Christian
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 626
    Daniel:
    BMGHB:
    Depends on country...
    I have analogue TV, and will for the next 10 years or so.
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
  • 10-18-2008 3:14 PM In reply to
    • lausvi
    • Top 150 Contributor
    • Helsinki - Finland
    • Posts 498
    • Gold Member
    Christian:
    Be glad about that!
    Here in FIN the analogue transmissions have ended and now we have to use digital receivers. Extra remote, and extra trouble for the user. Tv's own remote is almost useless, just use it to switch the tv on and off, perhaps volume. You have to fiddle with two remotes, both having control over some functions. On our summerhouse even a slight wind causes "NO SIGNAL" and before that the picture jamms, sound skips - it's SO annoying and frustrating. Then a lot of aerial adjusting and you might have one or two channels working... even if you move in the room it may stop working! The receivers are having low revisions of software and they can just stop working and you have to unplug it to make it work again. Translations of menus are poor, both receivers and remotes are made cheap and feel crap.... list goes on. When working the picture is good - as long as you don't mind the compression, it can be seen in most material.
    I miss so much the analogue days...
    Bang & Olufsen - The art of controlling sound, picture and light
  • 10-18-2008 3:34 PM In reply to
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    Christian:
    Daniel:
    BMGHB:
    Really, will Denmark continue 10 years with analogue TV? Sweden has closed it because the frequencies are needed for cellphones.
    Lausvi, if you have a B&O-TV you can always get a solution fron oneremote.dk or Lintronic.
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    Double post, sorry!
  • 10-18-2008 4:24 PM In reply to
    • lausvi
    • Posts 498
    • Gold Member
    Daniel:
     That's interesting that Denmark would keep analogue that long. In FIN I don't remember hearing the frequencies would be used for cellphones, I think it was told that free frequencies are needed to have more digital channels available.
    Daniel. I do have a Beovision now (refer to the "Beovision MX 3000 - found from a trash!"-topic. :) I know I could use programmable remotes etc. but my idea was in general level. I remember seeing a Beovisions that have a Topfield receiver mounted vertically on the tv's back! I recon they will get the remote signal thrue the set and from the Beolink? That was on my local B&O shop some year or two ago.
    I have a vintage 80's Salora videorecorder with a huge remote controller that can receive other remote's signal and save it to a certain button and then use it there. Somewhy the idea of learning remotes is not used nowadays. (Sorry to go slightly off-topic).
    For a Beovision LX5500 I would, too, recommend a Beolink 1000. :)
  • 10-19-2008 4:07 PM In reply to
    • henrik
    • Top 200 Contributor
    • Stockholm, Sweden
    • Posts 299
    Daniel:
    Do not forget analogue cable-tv, it is still very popular and over 50 % of the Swedish households are connected to a cable network. These networks also carry digital signals (DVB-C), but the majority of the households don't use it and many do as I do - I use DVB-C in the livingroom, and analogue in my bedroom.
  • 10-19-2008 4:19 PM In reply to
    henrik:
    Here in Finland we have no analogue transmissions left in the cable, either. Personally I haven't had an RF cable connected to my tv since 2004 or so - the analogue picture quality was always awful in this building...
    -mika
  • 10-20-2008 11:41 AM In reply to
    • Teaboy
    • Not Ranked
    • Posts 2
    Thanks for your help, Daniel.
  • 10-21-2008 2:57 AM In reply to
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    Your welcome!
    Please let us know when you've maked your choice.
