Latest post 10-14-2008 2:45 PM by Nebelfelsen. 1 replies.
Page 1 of 1 (2 items)
  • 10-14-2008 8:15 AM
    • mikey
    • Not Ranked
    • Joined on 10-11-2008
    • Posts 4
    Beovision 3 black edge
    Hi
    I have a beovision 3 - 28inch tv.  When I play DVD's through it there is always a thick black line all the way round the viewable picture (2 inchs wide).  I can make this disappear to some extent by using the format function.  However,  I wonder if my TV has been set-up correctly.  When I play my sky box through the TV on a terrestrial channel - say bbc1 then the whole of the screen is covered and there is no black border.  Is this normal or do I need to change a setting ?
    Mike
    Filed under:
  • 10-14-2008 2:45 PM In reply to
    Re: Beovision 3 black edge
    Which type of DVD player is used? B&O or third party?
    Most DVD players offer a screen size configuration in the settings menu to adjust the type of the screen (e.g. widescreen 16:9).
