Latest post 10-09-2008 1:02 PM by tiger57tel. 10 replies.
Page 1 of 1 (11 items)
  • 10-07-2008 1:20 PM
    Beogram 3000 (type 5901) and Beocenter 4000
    I've owned from new a Beocenter 4000 and a Beogram CDX which given years of great service.  I've just been given a Beogram 3000 (type 5901) which I was told played ok. My first problem was that the Beogram 3000 had a five pin connector & the Beocenter 4000 had jack plugs. After a visit to the local B&O shop an adapter cable was bought that had four jack plugs (red, white, black & yellow) I was told to use the red & white plugs & disregard the other 2. Following this advice I duly connected everything up & now have a 'hum' when the phono button on the Beocenter is selected & the 'hum' gets louder as the volume is increased. Can anyone help with this problem?
  • 10-07-2008 1:24 PM In reply to
    Re: Beogram 3000 (type 5901) and Beocenter 4000
    missing ground wire?
    • B&o bottle opener
  • 10-07-2008 1:55 PM In reply to
    Thanks Jeff - from where to where would the ground wire go?
  • 10-07-2008 2:18 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Welcome to Beoworld and thank you for supporting the site with your siver membershipSmile
    The ground/earth wire needs to run from the chassis (or any ground point) of the beogram to a same point on the beocenter.
    Chris.
  • 10-07-2008 2:23 PM In reply to
    thanks chris i will give it a go and let you know the results  terry
  • 10-07-2008 3:06 PM In reply to
    • Medogsfat
    • Posts 4,045
    Good luck Terry,
                            I'm pretty confident that earthing is your problem. Simply jam a bared end of a wire between the metal top plate of the beogram & chassis and do something similar with the beomaster and see the result. If it solves the humming then that's your problem a more permanent fix can be done.
    Chris.
  • 10-07-2008 3:08 PM In reply to
    hi chris tried the earthing between the deck & amplifier with no differance i disconnected the deck totally pushed the phono button and got the same noise its as if the deck is not connecting to the amp any ideas regards terry
  • 10-07-2008 3:09 PM In reply to
    Run a wire from the casing of the DIN plug to a metal part of the beocenter or to a convenient earth point. The Beocenter should have one really but I cannot see one on the manual.
  • 10-07-2008 3:50 PM In reply to
    hi peter tried what you suggested the humming has now gone,thanks very much, i am a bit disappointed that such a heath robinson [no disrespect] cure was required. the only thing now is poor sound quality i suspect the stylus is shagged any advice would be gratefully appreciated
  • 10-07-2008 4:46 PM In reply to
    The problem with the connection is due to the fact that the Beocenter 4000 was not actually made by B&O but in Japan and hence the odd connections. The Beogram RX had phono plugs to match.
    I suspect your diagnosis on the stylus is correct. I suggest Soundsmith is the best option but it is rather expensive.
  • 10-09-2008 1:02 PM In reply to
    thanks for your help much appreciated
    terry
