I managed to find imaculate S45-2 units to go with my 4400. They already sound amazing, however the speaker cable is patched together with sticky tape and I am sure it is the 'weakest link' in the system. Does anyone have any ideas on the best speaker cable to use for this. I guess I am stuck with the spade and pin male and female on each end of the cable. I do not want to hard wire the speakers with banana plugs to replace the spade and pin because the speakers are like new out of the factory! I have a lot of HitachiSSX-102k speaker cable spare, so I thought this would be good if I could get it connected properly to the Spade and Pin connectors. Any suggestions appreciated.
I am also looking for the best 5 pin din connector for the 4400 to connect to a PC 3.5" jack. Does anyone have any recommendations for the best quality cable?
