Latest post 10-03-2008 5:55 AM by jvdb107. 5 replies.
Page 1 of 1 (6 items)
  • 10-02-2008 3:32 PM
    BC2 + BV8
    WHen i press dvd and then switch to radio or tv the DVD keeps spinning :-(
    Any solutuions guys?
  • 10-02-2008 9:58 PM In reply to
    Re: BC2 + BV8
    I can check over the weekend. I did notice that it picks up playing where it stopped after changing the source back to DVD but can't tell if it stopped spinning. I think when paused, DVD would do that.
    Is yours connected through Scart and ML? Also what options are you using.
    Cheers
    JK
  • 10-03-2008 4:48 AM In reply to
    Re: BC2 + BV8
    jvdb107:
    Does it not stop after about 20min?
  • 10-03-2008 5:23 AM In reply to
    Re: BC2 + BV8
    bv 8 is in option 2 and BC2 in option 0
    Connected with master link and scart
     Haven't really tested if it stops after 20 mins
  • 10-03-2008 5:32 AM In reply to
    Re: BC2 + BV8
    jvdb107:
    See if it stops after a while... it might be a feature to allow quick resume...
    If you're viewing a video from VX recorder, when you switch to TV for example, the Video recorder pauses until you swich back to V.TAPE.
    If you leave it too long it will automatically leave the pause mode and stop.
    It might be the same for a DVD, as B&O handles all sources in a similar manner.
  • 10-03-2008 5:55 AM In reply to
    Re: BC2 + BV8
    LOL It has stopped  :-) great thanks everybody
