jvdb107: Haven't really tested if it stops after 20 mins
See if it stops after a while... it might be a feature to allow quick resume...
If you're viewing a video from VX recorder, when you switch to TV for example, the Video recorder pauses until you swich back to V.TAPE.
If you leave it too long it will automatically leave the pause mode and stop.
It might be the same for a DVD, as B&O handles all sources in a similar manner.
