1st March February 2012
Latest post 10-04-2008 5:56 PM by Christian. 9 replies.
09-30-2008 1:00 PM
ThePriest
- Joined on 10-19-2007
- Scandinavia
- Posts 254
Beosound 9000 type 2571 - which mk is this?
Hi I'm looking at a used Beosound 9000 with type number 2571, I don't know the year or SW version on this model yet. I think it's from 2001 but want to know if this is a mk II or mk III and what are the main different between the mk II and III? When I search the forum, I can see that one guy here have a type 2571 and he said that it's a mkIII with pin code protection, but if I look at the Beoworld Product guide it looks like that the mk III first starts from type 2572 and forward? this is what I found: So what's the difference between the different BeoSound 9000 versions?The MK I model is not upgradeable for N-Music The MK II model is upgradeable The MK III has a different CD mechanism and PIN code security. The glass plate has also undergone several updates as the earlier ones tended to come Types: Mark 1: 2522, Mark 2: 2562, Mark 3: 2572 what is correct? I'm a bit confused Also the deal is with a pair of Beolab 8000, but I have no clue how old they are, can this be see from a type lable or something? Thanks
Christian
- Joined on 04-16-2007
- Copenhagen, Denmark
- Posts 626
Re: Beosound 9000 type 2571 - which mk is this?
I think the last digit of the four is country specific. I think all mk III are 257x. Just checked: Mine is a 2571, and it is definitely mk III!
Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
Addicted? Oh no.... ;)
Christian
- Posts 626
You're welcome  You find the type no. under the panel with the buttons (betjeningspanelet bag lågen...). It lifts off and is held in one end by hinges and magnets in the other end - where there is a "hole" for a finger.
Gerd
- Joined on 04-20-2007
- Germany
- Posts 523
Type 2521 - 2531 = MK1 Type 2561 - 2570 = MK2
Type 2571 - 2580 and 2592 = MK3
ThePriest
- Scandinavia
- Posts 254
Thanks guys It's nice to get this help so fast, I can now tell the guy that the deal should be safe and considered a done deal. Then I can look into the SW version later on, maybe it's just fine as it's now. I will see the serial number tomorrow on the BL8000, so that might give me an idea which model. I still don't know if I will keep them as rear spearkers or sell them to fund a pair of BL3 Again Thanks guys
ThePriest
- Scandinavia
- Posts 254
Hi Guys Some new info - bad or good I can't tell. I have a question about 2.nd hand B&o product with PIN code protection.! Is't all good, if I only get a copy of the invoice or is it necessary to get hold of the original invoice, regarding future problems with PIN code issues or some other problems? One other thing that I think is odd, on the invoice there is only stated which product sold to the buyer, the serial number is not on the invoice, only the PIN code for the Beosound 9000. I got the serial numbers: Beosound 9000: Type 2571 SN:1803xxxx SW: 3.3 Beolab 8000: Type: 6801 SN: 1804xxxx So as far I can tell the BL8000 should be the newer upgraded version, so thats nice: "The changes are implemented form serial 16992475 onwards" Thanks
Weebyx
- Joined on 06-30-2008
- Denmark
- Posts 321
ThePriest: Hi Guys Some new info - bad or good I can't tell. I have a question about 2.nd hand B&o product with PIN code protection.! Is't all good, if I only get a copy of the invoice or is it necessary to get hold of the original invoice, regarding future problems with PIN code issues or some other problems? One other thing that I think is odd, on the invoice there is only stated which product sold to the buyer, the serial number is not on the invoice, only the PIN code for the Beosound 9000. I got the serial numbers: Beosound 9000: Type 2571 SN:1803xxxx SW: 3.3 Beolab 8000: Type: 6801 SN: 1804xxxx So as far I can tell the BL8000 should be the newer upgraded version, so thats nice: "The changes are implemented form serial 16992475 onwards" Thanks
On my invoices, there has always been stated the serialnumber also. /Weebyx
ThePriest
- Scandinavia
- Posts 254
Hi Guys
Thanks for helping.
I took the chance and bought the set, I will get the original invoice monday.
So this topic is now closed. To save space, the admin is allowed to delete it if needed.
Anders
Christian
- Posts 626
Congratulations on your purchase. I love my BS9000, and I am sure you will also. BS9000 and BL8000 is a classic. BR Christian
Page 1 of 1 (10 items)
