Latest post 05-15-2007 6:01 PM by classic. 5 replies.
Page 1 of 1 (6 items)
  • 05-14-2007 9:13 AM
    • Bill
    • Not Ranked
    • Joined on 05-14-2007
    • Posts 3
    Beolit 500
    I have obtained a Beolit 500 which having been on the Website is one of the 1965-1969 ones. It takes the weirdest of batteries but i have managed to get one from "The Small Battery Company" but for the princley sum of £9.65! . It also needs 6 D types as well. It is in awesome condition and comes in a special carry case with the Royal Crown on it and the original instruction booklet and warranty. I am expecting it to work beautifully and will know later this week when the B122 battery arrives; assuming it does work is it sort after and of any value?
  • 05-14-2007 11:06 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beolit 500
    It's a somewhat peculiar machine with radio and intercom in one.
    A design piece actually, though the true beauty of the design can be discussed.
    Hard to say if they are actually sought after, I never saw anyone looking to buy one but they are fairly rare, at least good condition ones and tend to go for reasonable amounts, even if non-working. The PVC carrying case instructions etc. only adds to the value.
  • 05-14-2007 1:04 PM In reply to
    • Bill
    • Not Ranked
    • Posts 3
    Re: Beolit 500
    Thanks very much for your reply very helpful if the battery comes tomorrow i will post my results!!??
    Cheers
    Bill Rusling
    Filed under:
  • 05-15-2007 8:10 AM In reply to
    • Bill
    • Not Ranked
    • Posts 3
    Re: Beolit 500
    Well the special little battery came this morning from The Small Battery Company and .... Yeah!! It not only works; but it sounds awesome!Does anybody else have any idea how much this might be worth? Bill
    Filed under:
  • 05-15-2007 11:49 AM In reply to
    Re: Beolit 500
    Bill
    I have quite a few Beolits, though as Martin points out, the 500 is an unusual member of the Beolit family being as it is a combined radio and intercom. Having never seen one for sale, it's hard to say, though I am sure there is some curiosity value attached to it. I guess the answer to the question is that it's worth what someone would be prepared to pay for it! If that's not helpful, I can tell you what I paid for some of the other Beolit models over the past year:
    1960s Beolit 600 - around £80ish for a nice set;
    1970s Beolit 600 - around £120ish for a nice set depending on the colour of the trim panels;
    Beolit 800 - around £100, though that particular set was a bargain in my opinion.
    Based on the above it might be fair to assume you might expect between £50-100???
    John
  • 05-15-2007 6:01 PM In reply to
    • classic
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Venø - Struer / Denmark
    • Posts 224
    Re: Beolit 500
    The Beolit 500
    This is a very rare product. If your Beolit 500 have all the 'printing' on the five push bottoms - it is very unusual.
    A mint condition Beolit 500 price level in Denmark is £200 or more.
    Technical the product is a bit unstable ? Perhaps the tuning is a problem.
    I like the Beolit 500 really, a rosewood version is very beautifull.
    Beolab 5000 -  "If another amplifier sounds different then it needs repair!"
    Filed under:
