I can hardly believe that they mess this up. I can the that the syncing works the way as described. I use my ipod that way actually, I din't want the movies to sync so I just drag the entire music section of the library onto the ipod and it is smart enough just to copy what is missing.
Apple lossless I would think they can easily add I would think but that is definitely a mistake.
&Trip you said at some point not to worry about a 2 way remote. Giving that nobody talks about it I do start now. The BS5 can be as "sexy" as it wants. If it ain't sitting on my lap I am not buying it.
