Latest post 09-24-2008 4:27 PM by TWG. 4 replies.
Page 1 of 1 (5 items)
  • 09-23-2008 3:39 PM
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    What's the difference between Scenes and Zones?
    could somebody explain to me what the exakt difference is between SCENES and ZONES?
    Actualy my brain seems to have some logical problem while operating the  Beo 5 when I  reach a  scene-screen.
     btw: there's a bad bug in the config tool 1.30: When you change the color of the button "ZONES" it doesn't work anymore!
  • 09-23-2008 3:50 PM In reply to
    Re: What's the difference between Scenes and Zones?
    Zones are rooms where you have a B&O TV or Hifi.
    Scene is a menu that is called by pressing the Semi Circle on the remote and that let you set the environment (scene) in a room: Light, Speakers configuration, Stand orientation, curtains, projector, Screen format.
    The Zone button is in the Scene menu!
  • 09-23-2008 6:59 PM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    Ok, thanks, I knew that ZONES = ROOMS, but I don't understand when I see which zone on the screen when I press on the scene button. Actualy I don't see the relation between those scenes.
    For example: Why do I see my bedroom on a scene related  to my living room?!
    Thank you for the tip with the scene-button! I'm gonna look for that tomorrow.
  • 09-24-2008 1:59 AM In reply to
    In the Scene menu, you have a Zone button that allow you to change the current zone, you also have a "Last zone" button that allow you to switch quickly to the last zone you were in.
    So in your case it might be "Bedroom". If you click in Bedroom, your remote will be configured to work in the Bedroom and in the Scene menu, the Bedroom button will be replaced by "Living Room" if it was the last zone used.
    p.
  • 09-24-2008 4:27 PM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    Now THAT helps me! Thank you for that explanation
