1st March February 2012
Latest post 09-09-2009 12:59 PM by 160EQ. 11 replies.
09-22-2008 2:57 PM
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Recently I aquired some Redline 60.2's with the original floorstands. Do these stands fit other Redline models? From what I can tell they would fit RL60's and RL45's, but not 100% sure. Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Craig
- Posts 4,855
Hi Peter, I have the twin pillar ones. Just trying to find out which models they fit. As I have only seen RL45's ,RL60's and RL60.2's up close I am unsure about other models. Craig
joeyboygolf
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
The mountings for 45, 45.2, 60, 60.2, 2000 and 6000 are identical and both types of floor stand can be used with any of them. The RL35 and RL1000 do not have floor stands but can be shelf mounted with a sort of L shaped prop! The stands and brackets for the RL140 and RL7000 are altogether bigger ( bit like the smaller ones on steroids ) and are only suited to those models.
richtoy
- Joined on 09-20-2007
- Valkenburg, Netherlands
- Posts 184
Hi The stands fit RL45s and RL60s and probably also their replacements. I did some research and recall that there were no stands for the RL35s. I have a pair of ceiling poles for the RL140 and these have a larger fixing bracket and do not fit RL45s or RL60s. The stands fetch quite a price on eBay. It is probably more cost effective to buy them with speakers. Regards Richard
Some of my B&O: BV3/32, MX7000, MX5500, LX5500, MX4000, BM8000, BM6000, Overture, BL8000, BM6000 Quad, BM4400, BM3400, BG-CDX, BM3000, BM1001, BM1200, BM1600, BM1700, BM1500, BM1400, BM2400, BM2300, BM4500, BM4000, BVM70, BVS45-2, BVS60, BC7700, BM2200, BM1900, BG8002, BM1202, BVPenta, BVP45
Craig
- Posts 4,855
Thanks for all the informative answers. These are going to be put in the for sale section, and I just wanted to get my information correct before I posted. Craig
Craig
- Posts 4,855
Another question about these stands. What holds the speakers in place? Should there be something that secures it, or is it just gravity that holds it in place? Craig
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
Craig there should be a square plate which bolts onto them and the speaker simply hooks onto these via the square hole in the back where the speaker wire terminals are and gravity does the rest. Chris.
Craig
- Posts 4,855
Medogsfat: Craig there should be a square plate which bolts onto them and the speaker simply hooks onto these via the square hole in the back where the speaker wire terminals are and gravity does the rest. Chris.
Thanks Chris, I have the plate which hooks into the square metal piece around the connections. Just wondered if there was anything else, as one of our members in interested in them. So naturally I want them to be complete. Craig
Medogsfat
- Posts 4,045
Yes Craig, they are complete then. They are adjustable directionally up/down by a dome head phillips screw which (IIRC) screws into the speaker and sits against the tab at the bottom of the mounting plate - fairly basic stuff but it does the job. Chris.
160EQ
- Joined on 09-09-2009
- Posts 1
I need help finding a pair of the square plates that interface between the speakers and the brackets. The plates were apparently originally supplied with my RL 45.2's? I have recently purchased these (45.2's) in mint condition and the ordered wall mount brackets from ebay only to find I was missing the connecting plates.
Ron
Page 1 of 1 (12 items)
