OK, so I've got a BeoTalk 1200 working nicely plugged into the phone socket along with BeoLine PSTN base, using the splitter supplied with BeoLine base. I've paired a BeoCom 6000 to the base, and it all works just fine. I can pick up the 6000 and get the handset icon in the display of BeoTalk 1200. And I can call this line from another phone and the BeoTalk will answer and let me leave a message. All good so far.
But, as I talked about in another thread, the phone socket is the opposite side of the house to where I want the phone and answer machine. No problem for the BeoCom 6000 of course. As for the BeoTalk, I think it was Sensotronic on here suggested a BT Diverse Cordless Socket; i.e. a DECT cordless 'client' with phone socket on it. I wasn't able to get one of these (they're no longer available) but I did manage to get a DistyBox300, which is pretty much the same thing. I've successfully paired it with the BeoLine base and am able to plug in a corded phone and it works.
But, when I plug the BeoTalk to this socket, it doesn't work properly. If I call the number, the BeoTalk will display the number calling but not answer the call. Also, when I lift the 6000 on the same line the handset icon does not appear in the BeoTalk display.
Does anyone have any idea what's going on here? The BeoTalk seems fine, because it works fine plugged into the main phone socket, and the DistyBox seems OK too because you can plug in a phone and make/receive a call.
Help!
