1st March February 2012
Latest post 04-14-2008 7:12 PM by Jandyt. 41 replies.
05-13-2007 3:07 PM
The Beonic Man
- Joined on 04-16-2007
- Bath
- Posts 426
This week I will have my new B&O equipment installed. When the dealer came to assess my appartment in terms of placement, I was rather suprised to find the result at the end of the morning significantly different to what I had first imagined although I have no complaints at all and have complete faith in his expertise and judgement. The main problem was wiring. It wasn't that it couldn't be done, it was more that I didn't want the aggravation of drilling holes through thick stone walls then having to fill and repaint. The setup we have chosen is right for the appartment and in fact, it was dictated by the type, size and acoustic capabilities of the appartment, not by what I actually wanted installed. A prime example is the decision to use a BV7-40 rather than a BV4-50 or BV5 as I had previously considered. With these points in mind, I can't help but wonder how many others are put off by the complexities of wiring and the work involved? Simon.
"We can rebuild him. We have the technology."
7-40, 7-2, 9000, BS3, BC2, LC2, BC6000, Beo5
The Beonic Man
- Bath
- Posts 426
I know what you mean Andy! That is exactly how I felt. There is no question that hard wiring a place throughout is great in terms of overall presentation but good grief, what a job it can be. Having just moved in and with so many other things to juggle around I just don't have this as a high priority and I am not even sure that I'd ever bother. Its interesting how I have ended up with a BeoVision 7-40. I keep laughing about it because I was intent on never getting one! Having said that it will be replaced immediately with the new 1080p version as soon as that comes out so I hope that will be a much improved television in terms of its picture, which for me, has always been a significant issue. I am also amazed that I have not ended up with surround sound which again, I thought was a dead cert! The dealer assured me that my appartment just wasn't able to repoduce it faithfully due to the odd design of the rooms. Its a converted 2 double bedroom appartment in a late 19th century Methodist Chapel (converted to 4 appartments in 1989). Of course I also have to take into account neighbours to the right and above, so volume levels would also be an issue. So, my B&O audio/video solution will simply be a BeoVision 7-40 with the 7.1 horizontal speaker under it. Quite different to my initial expectations! What TV do you use Andy? Do you think you will ever bother hiding the wiring in your place completly? Simon.
9 LEE
- Joined on 02-14-2007
- Moderator - UK
- Posts 5,223
A 7.1 with a 7-40. Really? What made you choose that?
Lee
The Beonic Man
- Bath
- Posts 426
9 LEE: A 7.1 with a 7-40. Really? What made you choose that?
Lee
BeoLab 7.2 is it then? The horizontal stereo spaker that sits underneath. Chosen because it was the dealer's recommendation. I am sure it will grow on me, B&O products have a marvellous way of achieving that!
9 LEE
- Moderator - UK
- Posts 5,223
The Beonic Man: 9 LEE: A 7.1 with a 7-40. Really? What made you choose that?
Lee
Ah.... 7.2, yes - that's the one that comes with the TV. Sorry, i thought you had deliberately chosen a 7.1 !!! If you're not having surround sound, the 7.2 is a better option. It's a cracking speaker in itself, and the bass it can produce is unbelievable! Lee
SWISS_2
- Neuchatel, Suisse
- Posts 552
It can be quite a task, especially on multi-level homes or Apartments. I have experienced 3 thus far, all just prior to the arrival of Beo Wireless. ( If I had only known when . . . ) But in hindsight, I was able to enjoy using the systems installed without too much fuss from the wife about cables and wires. Until the first of the many drillings. One needs: - A good look at the structure of the walls, taking into account load bearing versus non load bearing walls, arches, and beams. Think it out well.
- A heavy duty power drill, such as a Bosch suitable for masonry or concrete.
- More than a few LONG drill bits also for masonry and concrete, suitable for B&O cabling. Purchase the bit wide enough to allow additional cables to pass through such as SKY / SAT TV.
- Patience and strong biceps, triceps, and back muscles. ( Perhaps a Sauna or Hotspa afterwards )
- Vacumn, Broom, Brush, Dustbin, Safety Glasses, perhaps even gloves.
- Plaster, Paint, and minor repair kit items.
The rewards are that the lines and cables don't interfere with your Bang & Olufsen System. Also no tripping safety hazards, which will further avoid problems with the wife such as silence, death stares, sleeping alone, not being fed, locked out, or finding a cluge of cables and equipment thrown into the trash bin.
Peter
- Joined on 02-12-2007
- Posts 9,572
SWISS 2: Also no tripping safety hazards, which will further avoid problems with the wife such as silence, death stares, sleeping alone, not being fed, locked out, or finding a cluge of cables and equipment thrown into the trash bin.
Do you need a bed for the night?
jk1002
- Boston USA
- Posts 1,620
Sofar I soort of worked around it. I have a BS9000 wallmounted above my couch. Once I am finally settled in my new place I post pictures. I used one of those "aluminium rails" from B&O to hide the cable without rip my walls open. It covers the wall between BS9000 and couch and all the cable mess happens behind the couch. Would do the same with a BV4 wallmounted, use the rail and then hide the rest of cable and powercords behind furniture.
JK
Tom
- Luxembourg
- Posts 3,175
Lee
when I bought my BV7-32 a year ago, the 40" version had just come out. The TV would have been an option for me, but the BL7-2 would have been to large for the furniture it would have heen on. So I took the 32" version, also because of the price. But has anybody ever seen a BV7-40 with the BL7-1 underneath? I would like to see what it looks like.
Music washes away from the soul the dust of everyday life. - Berthold Auerbach
Keith Saunders
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
One of my pet hates is wires that can be seen in an otherwise lovely B&O environment. I have an Masterlink cable around my house on three floors connected to 11 B&O products. The time it has taken over the past years to implement it so the wires were always hidden has been considerable, but when I look at it today I am thankful I did it. Frankly what amazes me is that this is the one area where B&O are not good, I am talking cable management out of a product, I will use as an example the BeoVision 7 !! If you are using most/all of the main sockets, then making a neat job can be a challenge. Keith..
easyJan
- Belgium
- Posts 13
I just finished the wiring in my 200+ year old house. Actually do like this kind of things, finding solutions for practical problems. As we are living in the house, I didn't want to tear up too much walls/structures, yet as much cables as possible were to be hidden. Except for the outdoor speakers, all of them are active ones, so I decided to hide te power cabling as well. It ended with the whole hifi system having its own power supply circuit. Installing the cables themselves is by itself not that complicated, just ask your dealer for a cable scheme. There is more knowledge involved in connecting everything, but that was agreed upon to be done by the dealer. The whole thing can just be very time consuming. I started somewhere in august last year, and had everything installed two weeks ago. I must have broken a record for the slowest project ever. It surely didn't help I am gone for work most of the time (working for a UK company in Paris-living in Belgium), doing everything in my sparse free time. Very happy with the end result now -living room with surround and five link rooms, almost no visual cables. For me it was worth the effort and I learned a lot about the system, but also about my house and some renovating skills. The biggest challenge may be the patience of your wife. For that, I was very fortunate. Jan
Beonut
- Joined on 04-17-2007
- Essex, UK
- Posts 89
Kevin: I'm fortunate in our house as the whole thing is plaster boarded. The outside walls have a 25mm polystyrene inner and they are fixed to the wall with blobs of adhesive. If I want to lay a cable in I just saw a channel fit the cable put on a bit of plaster and repaper. The difficult bit is getting through the floors though as they are poured concrete and that IS tough stuff!
Kevin If its just powerlink / masterlink cables not mains cables, I remove my skirting board and run the cables behind then up the wall in the stud work, this is safe for all low voltage cables but not for mains cables and avoids going under / into the floor. Relevant to UK users, I think i have found a tidy way for dealing with letting the powerlink cable out of the wall along with the power cable for the speaker, I use a connection unit from MK which has the flex outlet at the bottom, I bring the power link cable out of the wall just below the connection unit, the mains flex comes out of the bottom of the connection unit and then put both cables into the B&O cable cover. I know some people dont like the B&O cable covers, Ive also found the above method works well without the covers as if necessary both cables can be taped together with black tape. Ive added pics Cheers Peter
My B&O - BS3, BV4-50, Beomedia 1, BS3200, DVD1, BL8000, BL6000, BL3, BL2, BL7.4
B&Ola
- Posts 302
I've found a nice product to do good-looking cable installation. These skirting-boards are made of MDF (thats what they call it here in Sweden) and are realy high quality. The price, here in Sweden, is 35€ for 2 pcs of 240cm. Very easy installation with mounting clips for non visible screws etc. http://www.kanallisten.com/ (In swedish only, sorry) Send me a PM if you want somthing translated. /Ola
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
At some point I will tidy up my wiring. Next time we decorate it will get put in to the walls. Honest Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Morgan
- Joined on 04-19-2007
- Spain
- Posts 2,271
B&Ola: I've found a nice product to do good-looking cable installation. These skirting-boards are made of MDF (thats what they call it here in Sweden) and are realy high quality. The price, here in Sweden, is 35€ for 2 pcs of 240cm. Very easy installation with mounting clips for non visible screws etc. http://www.kanallisten.com/ (In swedish only, sorry) Send me a PM if you want somthing translated. /Ola
Does anyone know other system similar to this one or a web with information about it (in English, please)
Rafa
