1st March February 2012
09-13-2008 3:53 PM
nmartin771
- Joined on 02-18-2008
- Novi Sad, Serbia
- Posts 3,103
Hello,
I need little help. I'm a proud owner of Beosystem 2300 and now I want to by BeoLab 4000 MK1. Can I connect at the same time beolab 4000 to BS2300 and my PC ? I want to lisen musick from BS2300 and from my PC on beolab4000? And of course can you halp me how to conect this?
One more question: in the future I want to by another pair of beolab 4000, is it possible to connect 2 pair of BL4000 - beosystem 2300 and PC ?
Thank you very much!
Nikola
when your Black Label begin to taste like juice just take shot or two of Absinthe and
after that quench with some vodka, if you still feel juice like take beer
with grappa !
Peter
- Joined on 02-12-2007
- Posts 9,572
Re: BeoLab 4000 - connection
Connecting two sources on the whole is not a good idea. The 2300 unfortunately does not support a Beoport but there is still a solution. Have a look at this product. It will also give you control of your PC music.
Peter
- Posts 9,572
And I forgot, yes, you can connect another pair of Beolab 4000s by daisy chaining them.
nmartin771
- Novi Sad, Serbia
- Posts 3,103
Hello Peter, Thanks for quick replay....
I'm not shure that I understand what its mean "daisy chaining them." Can you explain me how I can do that?
And I saw this product that you show me, this I need to connect to my beosystem 2300 ?
with grappa !
Peter
- Posts 9,572
The product connects the BC2300 to your computer. Daisy chaining uses the fact that each Powerlink cable carries both right and left signals which are selected by a switch on the Beolab 4000. There are two Powerlink sockets on the speaker - you attach one cable from the 2300 to the speaker and then connect another cable to the speaker and run it to the second speaker. You can actually connect up to ten pairs this way if you want!
nmartin771
- Novi Sad, Serbia
- Posts 3,103
Great! I didnt know that.... than I have one more left powerlink on my 2300 so that I can conect pc to it...
And where I can buy this little cable? or I simly go to the shop that making cables and tell them ?
with grappa !
nmartin771
- Novi Sad, Serbia
- Posts 3,103
Seams logical to me...
gorissek, vidim da si iz Slovenije, ja sam iz Srbije - Novi Sad :) Kakav sistem imas? Ja sam veliki fan B&O...
with grappa !
Peter
- Posts 9,572
The PC connects to the Aux socket and you control the PC via the 2300 - I think I may have confused you! The cable shown is a bespoke one made by one of our Beoworld members, Ridax. I believe you can order one via his site.
nmartin771
- Novi Sad, Serbia
- Posts 3,103
I dont want to control my pc via BS2300, I simply want to play music from my PC, MAC to my beolab4000 nothing else, plug 3,5 mm jack to my comp. and play music.
maby I confused....
with grappa !
Peter
- Posts 9,572
In that case, just run a cable from the audio out to the Aux in of the 2300.
gorissek
- Joined on 04-16-2007
- EU
- Posts 234
And this is how the cable looks like. Ask your dealer, he should have them. PS. Zivjo, lepo videti se nekoga iz blizine. Kaj imam pa lahko vidis v profilu.
nmartin771
- Novi Sad, Serbia
- Posts 3,103
Great ! That is what I wanted to hear :) simple and easy :)
Thanks Peter!
with grappa !
nmartin771
- Novi Sad, Serbia
- Posts 3,103
I ja sam se obradovao :)
Impresivno... kod mene je situacija ovakva Beosystem 2300, Beocenter 1, Beocom 2500. Napadam sad beolab 4000 i beocom 2 :)
Vidim da imas sajt, cime se bavis ?
Ovo je moj sajt www.nmartinproject.com
with grappa !
gorissek
- EU
- Posts 234
Predvsem s designom - industrijski in graficni. Me pa zanima tudi to, s cimer se ukvarjas ti - zanimivi projekti : ) Mislim, da je pametno da ne smetiva vec tukaj gor, lahko pa preko PM.
Dave
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
gorissek: Predvsem s designom - industrijski in graficni. Me pa zanima tudi to, s cimer se ukvarjas ti - zanimivi projekti : ) Mislim, da je pametno da ne smetiva vec tukaj gor, lahko pa preko PM.
Oh i agree
Steve at Sounds Heavenly
- Joined on 05-18-2007
- In the cable workshop, Melton Mowbray, UK
- Posts 356
Thanks Gorissek, I'm glad that my cables are being seen on BeoWorld! I currently have a number of dealers in the UK who keep these in stock (including LifeStyle AV where your picture came from) and I'm hoping to offer these to franchises across Europe during the coming months. These iPod cables are intended to be true "hifi" cables for B&O, instead of the usual "bits of wire" of varying quality that are often on offer...... Best regards, Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
Page 1 of 1 (18 items)
