1st March February 2012
Latest post 05-14-2007 11:07 AM by PAJ. 14 replies.
05-13-2007 4:56 AM
js01
- Joined on 05-13-2007
- Posts 3
Hi my bs9000 makes a high pitched whine when it plays any of the 6 cds , I have checked the playing controls on the back of the unit.Any ideas
Peter
- Joined on 02-12-2007
- Posts 9,572
There is a failt noted in some earlier 9000s where the clamper arm can become slightly bent. This results in a scraping sound on playback. This can be adjusted but is best done by your dealer as it really needs the test CD and you have to take the glass door and clamper cover off. If it is that, it may be covered by B&O.
petermc
- Joined on 04-16-2007
- Shepparton, Australia
- Posts 87
I have had my BS 9000 for over 2 years and it has made the same high pitched whine since day one. I thought it might be a problem but the 9000 in the B&O store also did it. Could be something to do with it being semi-open (ie. glass cover is not fully enclosed/sealed). Peter
Daniel
- Joined on 04-17-2007
- Svinarp, Sweden
- Posts 1,284
Mine does it to. First I had B&O to change the CD mechanism, but it was the same again. I only hear sitting in the chair under the BS9000 playing on low volumes. I guess it´s because the open design of the player. Doesn´t bother me any longer.
Santiago
- Switzerland
- Posts 3,286
I also can hear the CD spinning inside my BS9000, but only when:
the music is mute, the room is absolutely quiet, and my ear is closer than 15 cms from glass panel closed or 30cms with the glass door open. I never use the BS9000 in those conditions, so everything it's all right for me.
mobeyone
- Joined on 03-27-2007
- UK
- Posts 955
The 9000 will make a sound when playing, this is normal and depends I think on the thickness on the cd. The sound that I think JS is reporting here is a whine which is very different. I had the same and was fixed by replacing the CD mech. The whine is very high pitched and not a scraping sound that the cd makes when spinning. Get your local service center to have a look at it and take it from there. iirc it was in the region of £200 to replace.
Page 1 of 1 (15 items)
