1st March February 2012
Latest post 01-12-2009 1:24 PM by Beobuddy. 31 replies.
08-28-2008 11:08 AM
halid
- Joined on 02-19-2008
- Posts 124
Hi, those anyone know if the mediaplayer Popcorn Hour can be added to the STB-list in my 7-40 MK III ? Best regards Hans
jk1002
- Joined on 04-16-2007
- Boston USA
- Posts 1,620
Your dealer can create a custom STB for you for this device. He would just need the remote & device for testing. Is not difficult to do. Cheers JK
hebo
- Sweden
- Posts 305
Is it possible to create a custum STB for a BV6-26 as well??? type nr 9250
kawo
- Joined on 04-17-2007
- Posts 516
The dealer can create a customized STB entry? This is new to me....as far as I know B&O is "willing" to compile a customer specific PUC for a certain device for a fee (aprox. 500 Euro or so). However, on the most recent PUC list there is the Dvico 6500 media player, not to bad... Karsten
_________________________________________________________________________
BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
jk1002
- Boston USA
- Posts 1,620
Yes they can. I don't know about the cost and owuld think it is different from dealer to dealer but when I bought my BV8 the dealer said it is relativly easy since we were not sure if Apple TV would work. It might be they send the device just off to headquarters but I think that is what the STB software does that the dealer has. It was mentioned in the launch document for the BV8 as well if I recall correct. Cheers JK
hebo
- Sweden
- Posts 305
I would like to control a Samsung DTB 850P, is it in the latest puc-list? or can my dealer "copy" the IR and convert them into a STB-table?
Sal
- Joined on 04-30-2007
- Indianapolis, USA
- Posts 261
Stupid question, I apologize for my ignorance... What does "PUC" stand for?
Love B&O, but no longer addicted.
jk1002
- Boston USA
- Posts 1,620
Re: I should know this...
Perepherie Unit Controller I believe. JK
mr_anders_son
- Joined on 03-27-2007
- sweden
- Posts 1,032
hebo: I would like to control a Samsung DTB 850P, is it in the latest puc-list? or can my dealer "copy" the IR and convert them into a STB-table?
Samsung DCB-P850 is there. This is the cable box, but I think it is the same as DTB = Terrestrial
hebo
- Sweden
- Posts 305
Thanx mr_ander_son I just wonder if the stb-table is on a chip or if it´s made by flashtool on my BV6-26 type 9250? I know the sw is updated by my dealer with flashtool, but what about the stb-table???
Keith Saunders
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
The Set-top Box Controller (STB-C) information was replaced by PUC/IR-Table Generator information. The STB-C Set-Top Box Controller was given a new name of Peripheral Unit Controller (PUC) to reflect the fact that products other than standard STB's were able to be controlled and the PUC can be updated from a PC loaded with the B&O software via pins 9 & 10 of the Masterlink socket. The STB controller in older products can only be updated by changing a chip on the STB controller module. Newer B&O products can be updated by the dealer and he can generate a customised IR table for your PUC from a library of available units. The library currently has 5 sections namely:- - STB
- Home Media (Microsoft, Apple, Sony & TVX
- DVD
- VCR
- Projector
If the unit you wish to control is NOT in the library, then the dealer cannot produce the IR code download, but can request one be produce by Denmark for which a charge will be made. The dealer does NOT normally produce the actual IR codes for a device, he/she just selects the required package of codes from a pre-built list from within a B&O software package. The Beocentre 6 STB-C/PUC can be updated with a flash download, but I believe the Beovision 6 cannot.
hebo
- Sweden
- Posts 305
Thanx for the info Keith. Straighten out the questionmarks as usual:-) Now I understand it a bit more.
Keith Saunders
- Posts 3,810
I guess you edited your most recent posting because the e-mail I received has 3 more lines than your posting. In answer to your question missing from the posting about Table 3.91 North Europe 4.0. The short answer is "yes"
hebo
- Sweden
- Posts 305
Thank you Keith The question I had was if my dealer can update my stb-table to NE 4.0.
k984942
- Joined on 11-10-2008
- London, UK
- Posts 194
Hi Do you know if the latest STB-C table for an Avant (non-RF, VCR model) is 3.91? If so, can you point me in the right direction of where I can find out what devices are on this list before I actually pay for an upgrade. Thanks
32" RF VCR Avant, 2 x 28" VCR Avant, DVD1, Beocom 6000, Beo5, A9 Keyring!
Keith Saunders
- Posts 3,810
Due to the limited space in the software chip, the set-top box codes have been split into five seperate IC chips by region as below North Europe, version 4.00 with part number 8344784 West Europe, version 4.01 with part number 8344785 Central Europe, version 4.06 with part number 8344786 South Europe, version 4.03 with part number 8344787 Asia, version 4.04 with part number 8344788 The content of the Northern European chip is:- 1. KREATEL IP-STB 2. Samsung SMT-H3106 3. Samsung DSB-B560N 4. Motorola VIP1216E DK 5. Amino AmiNET110 6. KISS KMM3000 7. Apple Remote 8. Motorola VIP 1920 9. CANALdig DK/S/N 10. Thomson SkyHD 11. Sagem ITSD81HD 12. SAGEM DVR6240FL FR 13. Dilog DT-355 14. Dilog DT-550DVR 15. Samsung DCB-P850RS 16. Fantacy IP-7000 17. CDC 5000 18. CDC 7000 TS 19. DREAMBOX DM7000 20. FORCE 1145S/89S 21. NOKIA 260S 22. NOKIA 9800S/02S 23. PACE DS420 24. SAMSUNG 9500Z 25. SKY DIGITAL 26. STRONG SRT 5200 27. THOMSON DTI35x 28. TRIAX DSI 35xTX 29. TRIAX DVB 360S 30. CANALdig C1201CX 31. CDC KCFN550H2CO 32. Get KCF-2000NS 33. Get KCF-3000NS PVR 34. Grundig DTR8720 35. NOKIA 9902S 36. PACE DS230 37. PACE DS460NV 38. REBOX RE-1250CO 39. SAGEM 81 HD 40. SELECTOR 41. THOMSON DSI420
csmager
- Joined on 05-09-2008
- Posts 213
Keith Saunders: Products in the "Home Media" section which dealers can download into the PUC are:-
Thanks Keith. You wouldn't happen to know if that's the original Xbox or the Xbox 360? Would seem a bit strange to have PS3 and original Xbox. If it's 360, we're in business as Windows Media Center can be controlled with the Xbox 360 remote.
csmager
- Posts 213
Unfortunately I don't, but thanks for the offer. I searched the forum for Xbox, and it seemed to hint at it being for the original, but I couldn't find a post from someone who'd actually tried it. I haven't got a BS3 yet (on the plan for next year sometime!), as that's what I'd be wanting to control MCE with. Weebyx has managed to control it using any old STB profile (being a PC, you can bodge it to accept any IR command and translate it to something Media Center might understand), but understandably it being able to do it off the bat would be far more preferable! Thanks for the help!
k984942
- London, UK
- Posts 194
Thanks for the information on the latest STB table for an Avant. The thing is, I can't seem to see Virgin V+ on this list, yet my dealer is in the process of ordering me the chip as he claims V+ is on the list! Can anyone clarify this please? If he's wrong I still have time to cancel the order. Also, as I'm not familiar with all the devices in the list, can anyone suggest which are DVD players? Thanks for your help as always
Large48
- Joined on 06-24-2008
- London
- Posts 455
Hi, do those part numbers come with a fixing kit etc? Cheers GUY
Train Hard - Run Fast - Hit to Kill!!!
