Latest post 01-12-2009 1:24 PM by Beobuddy. 31 replies.
Page 1 of 2 (32 items) 1 2 Next >
  • 08-28-2008 11:08 AM
    STB-list
    Hi, those anyone know if the mediaplayer Popcorn Hour can be added to the STB-list in my 7-40 MK III ?
    Best regards
    Hans
  • 08-28-2008 9:34 PM In reply to
    Re: STB-list
    Your dealer can create a custom STB for you for this device. He would just need the remote & device for testing. Is not difficult to do.
    Cheers
    JK
  • 08-29-2008 1:27 AM In reply to
    • hebo
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Sweden
    • Posts 305
    Re: STB-list
    Is it possible to create a custum STB for a BV6-26 as well???
    type nr 9250
     BV10
  • 08-29-2008 9:05 AM In reply to
    • kawo
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 516
    Re: STB-list
    The dealer can create a customized STB entry? This is new to me....as far as I know B&O is "willing" to compile a customer specific PUC for a certain device for a fee (aprox. 500 Euro or so).
    However, on the most recent PUC list there is the Dvico 6500 media player, not to bad...
    Karsten
    _________________________________________________________________________
    BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
  • 08-29-2008 9:11 AM In reply to
    Re: STB-list
    Yes they can. I don't know about the cost and owuld think it is different from dealer to dealer but when I bought my BV8 the dealer said it is relativly easy since we were not sure if Apple TV would work. It might be they send the device just off to headquarters but I think that is what the STB software does that the dealer has. It was mentioned in the launch document for the BV8 as well if I recall correct.
    Cheers
    JK
  • 08-29-2008 10:04 AM In reply to
    • hebo
    • Sweden
    • Posts 305
    Re: STB-list
    I would like to control a Samsung DTB 850P, is it in the latest puc-list?
    or can my dealer "copy" the IR and convert them into a STB-table?
     BV10
  • 08-29-2008 10:27 AM In reply to
    • Sal
    • Joined on 04-30-2007
    • Indianapolis, USA
    • Posts 261
    I should know this...
    Stupid question, I apologize for my ignorance... What does "PUC" stand for?
    Love B&O, but no longer addicted.
  • 08-29-2008 12:40 PM In reply to
    Re: I should know this...
    Perepherie Unit Controller I believe.
    JK
  • 08-30-2008 2:39 AM In reply to
    Re: STB-list
    hebo:
    Samsung DCB-P850 is there. This is the cable box, but I think it is the same as DTB = Terrestrial
  • 09-03-2008 4:51 AM In reply to
    • hebo
    • Sweden
    • Posts 305
    Re: STB-list
    Thanx mr_ander_son
    I just wonder if the stb-table is on a chip or if it´s made by flashtool on my BV6-26 type 9250?
    I know the sw is updated by my dealer with flashtool, but what about the stb-table???
     BV10
  • 09-03-2008 6:20 AM In reply to
    Re: STB-list
    The Set-top Box Controller (STB-C) information was replaced by PUC/IR-Table Generator information.
    The STB-C Set-Top Box Controller was given a new name of Peripheral Unit Controller (PUC) to reflect the fact that products other than standard STB's were able to be controlled and the PUC can be updated from a PC loaded with the B&O software via pins 9 & 10 of the Masterlink socket.
    The STB controller in older products can only be updated by changing a chip on the STB controller module.
    Newer B&O products can be updated by the dealer and he can generate a customised IR table for your PUC from a library of available units. The library currently has 5 sections namely:-
    1. STB
    2. Home Media (Microsoft, Apple, Sony & TVX
    3. DVD
    4. VCR
    5. Projector
    If the unit you wish to control is NOT in the library, then the dealer cannot produce the IR code download, but can request one be produce by Denmark for which a charge will be made. The dealer does NOT normally produce the actual IR codes for a device, he/she just selects the required package of codes from a pre-built list from within a B&O software package.
    The Beocentre 6 STB-C/PUC can be updated with a flash download, but I believe the Beovision 6 cannot.
    Regards Keith....
  • 09-03-2008 8:51 AM In reply to
    • hebo
    • Sweden
    • Posts 305
    Re: STB-list
    Thanx for the info Keith. Straighten out the questionmarks as usual:-)
    Now I understand it a bit more.
     BV10
  • 09-03-2008 9:20 AM In reply to
    Re: STB-list
    I guess you edited your most recent posting because the e-mail I received has 3 more lines than your posting.
    In answer to your question missing from the posting about Table 3.91 North Europe 4.0. The short answer is "yes"
    Regards Keith....
  • 09-03-2008 9:28 AM In reply to
    • hebo
    • Sweden
    • Posts 305
    Re: STB-list
    Thank you Keith
    The question I had was if my dealer can update my stb-table to NE 4.0.
     BV10
  • 11-20-2008 5:56 AM In reply to
    • k984942
    • Top 500 Contributor
    • Joined on 11-10-2008
    • London, UK
    • Posts 194
    Re: STB-list
    Hi
    Do you know if the latest STB-C table for an Avant (non-RF, VCR model) is 3.91?
    If so, can you point me in the right direction of where I can find out what devices are on this list before I actually pay for an upgrade.
    32" RF VCR Avant, 2 x 28" VCR Avant, DVD1, Beocom 6000, Beo5, A9 Keyring!
  • 11-20-2008 6:57 AM In reply to
    Re: STB-list
    Keith Saunders:
    1. STB
    3. DVD
    4. VCR
    5. Projector
    Keith - can you expand on section 2?  You say Microsoft - do B&O now have the STB codes for Windows Media Center?  I can't think of much else MS make that it could control...
  • 11-20-2008 7:11 AM In reply to
    Re: STB-list
    Products in the "Home Media" section which dealers can download into the PUC are:-
    • Apple Remote
    • Microsoft Xbox
    • Sony Playstation 3
    • TViX M6500A HD
    • TVX HD M-5000A
    • TVX M-4110SH
    Regards Keith....
  • 11-20-2008 7:28 AM In reply to
    Re: STB-list
    Due to the limited space in the software chip, the set-top box codes have been split into five seperate IC chips by region as below
    North Europe, version 4.00 with part number 8344784
    West Europe, version 4.01 with part number 8344785
    Central Europe, version 4.06 with part number 8344786
    South Europe, version 4.03 with part number 8344787
    Asia, version 4.04 with part number 8344788
    The content of the Northern European chip is:-
    1. KREATEL IP-STB
    2. Samsung SMT-H3106
    3. Samsung DSB-B560N
    4. Motorola VIP1216E DK
    5. Amino AmiNET110
    6. KISS KMM3000
    7. Apple Remote
    8. Motorola VIP 1920
    9. CANALdig DK/S/N
    10. Thomson SkyHD
    11. Sagem ITSD81HD
    12. SAGEM DVR6240FL FR
    13. Dilog DT-355
    14. Dilog DT-550DVR
    15. Samsung DCB-P850RS
    16. Fantacy IP-7000
    17. CDC 5000
    18. CDC 7000 TS
    19. DREAMBOX DM7000
    20. FORCE 1145S/89S
    21. NOKIA 260S
    22. NOKIA 9800S/02S
    23. PACE DS420
    24. SAMSUNG 9500Z
    25. SKY DIGITAL
    26. STRONG SRT 5200
    27. THOMSON DTI35x
    28. TRIAX DSI 35xTX
    29. TRIAX DVB 360S
    30. CANALdig C1201CX
    31. CDC KCFN550H2CO
    32. Get KCF-2000NS
    33. Get KCF-3000NS PVR
    34. Grundig DTR8720
    35. NOKIA 9902S
    36. PACE DS230
    37. PACE DS460NV
    38. REBOX RE-1250CO
    39. SAGEM 81 HD
    40. SELECTOR
    41. THOMSON DSI420
    Regards Keith....
  • 11-20-2008 8:18 AM In reply to
    Re: STB-list
    Keith Saunders:
    • Microsoft Xbox
    Thanks Keith.  You wouldn't happen to know if that's the original Xbox or the Xbox 360?  Would seem a bit strange to have PS3 and original Xbox.
     If it's 360, we're in business as Windows Media Center can be controlled with the Xbox 360 remote.
  • 11-20-2008 12:02 PM In reply to
    Re: STB-list
    Whilst I would expect it to be the Xbox 360, I don't know for sure.
    However, if you have a Beo5 I can provide an XML file for you to test. If it works or not in the Beo5 will provide the answer..
    Regards Keith....
  • 11-20-2008 12:12 PM In reply to
    Re: STB-list
    Unfortunately I don't, but thanks for the offer.  I searched the forum for Xbox, and it seemed to hint at it being for the original, but I couldn't find a post from someone who'd actually tried it.
    I haven't got a BS3 yet (on the plan for next year sometime!), as that's what I'd be wanting to control MCE with.  Weebyx has managed to control it using any old STB profile (being a PC, you can bodge it to accept any IR command and translate it to something Media Center might understand), but understandably it being able to do it off the bat would be far more preferable!
    Thanks for the help!
  • 11-20-2008 12:37 PM In reply to
    Re: STB-list
    Well, perhaps we can open the question up to other Beoworld members who may have a Beo5 and an Xbox.
    If anyone has an Xbox and a Beo5 with the configuration software, then I can provide an XML file for you to test.
    Regards Keith....
  • 12-18-2008 5:42 AM In reply to
    • k984942
    • London, UK
    • Posts 194
    Re: STB-list
    Thanks for the information on the latest STB table for an Avant.
    The thing is, I can't seem to see Virgin V+ on this list, yet my dealer is in the process of ordering me the chip as he claims V+ is on the list!
    Can anyone clarify this please? If he's wrong I still have time to cancel the order.
     Also, as I'm not familiar with all the devices in the list, can anyone suggest which are DVD players?
    Thanks for your help as always
  • 12-18-2008 7:49 AM In reply to
    • Silou
    • Joined on 08-10-2007
    • Switzerland
    • Posts 241
    • Gold Member
    Re: STB-list
    Does anybody make an home made interface to program himself the PUC ?
  • 12-20-2008 7:37 AM In reply to
    Re: STB-list
    Hi, do those part numbers come with a fixing kit etc?
    Cheers
    GUY
    Train Hard - Run Fast - Hit to Kill!!!
