jeremydillon:
CAUTION!
This is secondary side!!
But doing the same on primary side would be the reverse: converting 220 to 110V.
Each winding has to get 110V so no paralleling but serialling the windings.
This is RX2 supplement but I think valid for BG5000 too.
EDIT: Martin you would be right for secondary side modification but I've always seen voltage conversion on primary side only, mostly because of wattage...![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.00.28.62/RX2_2D00_PS.jpg)
hx
