Latest post 03-08-2011 3:40 AM by jeremydillon. 14 replies.
Page 1 of 1 (15 items)
  • 08-28-2008 1:16 AM
    Change voltage of beogram 5000 from 110 to 240
    Is there a simple way to change the voltage of my beogram 5000 (picked up cheap on ebay) to 240v or am I best just to use an external transformer?.  Also, will there be any issues using 50hz not 60hz?
  • 08-28-2008 3:16 AM In reply to
    Re: Change voltage of beogram 5000 from 110 to 240
    Looks like a simple wire change on the mains transformer. Suggest that you download the service manual!
    Regards Graham
  • 03-07-2011 12:44 AM In reply to
    i've finally gotten around to doing this ... just after a little hand holding to make sure I do it right.
    Here are some pictures of mine as it is as a 110v ... I'd love to see someone's 240v version before I start cutting and resoldering.
  • 03-07-2011 12:51 AM In reply to
    This is my plan ....
  • 03-07-2011 2:37 AM In reply to
    jeremydillon:
    If it's a DC motor (which it is) no problem. If you change the AC voltage on a AC driven motor (like the Beogram 4002) then you surely will hear the results. That's what I've all learned during my membership on this forumSmile
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 03-07-2011 3:36 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Aren't the voltage setting done on the transformer primary ?
    I don't remember if it is, but if it's done on the secondary as you show, what you suggest looks right.
  • 03-07-2011 3:55 AM In reply to
    jeremydillon:
    CAUTION!
    This is secondary side!!
    But doing the same on primary side would be the reverse:  converting 220 to 110V.
    Each winding has to get 110V so no paralleling but serialling the windings.
    This is RX2 supplement but I think valid for BG5000 too.
    EDIT: Martin you would be right for secondary side modification but I've always seen voltage conversion on primary side only, mostly because of wattage...
    hx
  • 03-07-2011 4:07 AM In reply to
    • Dillen
    • Posts 5,008
    Exactly.
    Could you please provide a photo of the primary side ?
  • 03-07-2011 4:10 AM In reply to
    Thanks Hemenex ... that seems to make a lot more sense and the diagramme seems to confirm it.
    I'm not near the deck now so I can't have a look and take more pictures. I'll have to do it in the morning.
    I light of this near miss I'll let you guys have a look over my new plan before I do something drastic.
    Thanks again ... its great to have so much experienced help so close at hand.
    Cheers
    Jeremy
  • 03-07-2011 4:38 AM In reply to
    Dillen:
    Wasn't that easy as there is no chance to get the primary side without removing the transformer Surprise
    But I luckily have one for repair right here so I took the chance - here it is:
    (remember this is 220V setting)
    HTH & good luck to Jeremy
      hx
  • 03-07-2011 7:56 AM In reply to
    • Dillen
    • Posts 5,008
    Yes, the voltage setting is done on the primary side.
    You will have to move the red'ish brown lead and establish the connections
    shown in the diagram.
    The secondary side is fine and should not be touched.
  • 03-07-2011 7:26 PM In reply to
    Here is the 110v version for the record
  • 03-07-2011 7:31 PM In reply to
    this is what I will do ...
    Thanks again everyone
  • 03-08-2011 2:59 AM In reply to
    • Dillen
    • Posts 5,008
    Looks fine.
  • 03-08-2011 3:40 AM In reply to
    yes ... did it this afternoon. Works great!
    Jeremy
