Hello
I corrected the spindler height and the focus offset and the focus bandwidth using as reference feedback the eye-pattern. I adjusted the laser output too to have the Eye pattern at 1Vpp.
Now the cd player works great, tracks are find correctly and the traking works well BUT... The "?" ("error" on others display) still appears.
The scenario is this, the cover is removed and I put the clamper manually on the CD and then power up the unit. I noticed that when the "?" appears is after these operations:
1) Focusing state
2) Spindle start
3) Toc reading => here the "?" appears.
I noticed that if I power off the unit and remove the cd and put in place again the problem is solved and when repowering the problem doesn't appears anymore.
Could be an angle setting problem?
Is there on sale the glass disc and the mirror?
Thanks a lot from the CDX too
Eugenio
