Latest post 09-02-2008 3:24 PM by henrik. 9 replies.
Page 1 of 1 (10 items)
  • 08-26-2008 11:22 AM
    • Robilu
    • Not Ranked
    • Joined on 08-26-2008
    • Posts 3
    Beomaster 4000 plus Cd player query
    Can anyone tell me exactly what I need to do to play a modern CD deck through a Beomaster 4000 tuner/amp (presumably via 'Tape 1 or Tape 2 din inputs) - is a preamp required, and if so what is recommended? Thanks.
    Filed under:
  • 08-26-2008 11:46 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beomaster 4000 plus Cd player query
    Hi and welcome to Beoworld !
    You only need an adapter cable going from whatever plug your CD deck has (presumably 2x RCA) to a 5-pin DIN. YOu can connect to any of the two tape inputs as you please. Your local dealer will have an adapter or you can find one at Ebay.
  • 08-26-2008 3:04 PM In reply to
    • Robilu
    • Not Ranked
    • Posts 3
    Thanks for the speedy response. How about an ipod or personal stereo as the input (i.e. via single 3.5 phono connection)  -- can they plug in directly in the same way?
     Robin
  • 08-26-2008 4:53 PM In reply to
    • Dillen
    • Posts 5,008
    Yes, the Beomaster will accept anything at line level.
  • 08-26-2008 5:28 PM In reply to
    • Robilu
    • Not Ranked
    • Posts 3
    Thanks very much. I will go ahead.
    Robin
  • 08-27-2008 2:56 PM In reply to
    • lausvi
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Helsinki - Finland
    • Posts 498
    • Gold Member
    Robilu:
     An iPod will certainly work. The problem might be that you'll need to raise the volume higher than with other inputs as the iPods output isn't exactly line level even at full volume (remeber to turn the volume limiter to max in the settings of the iPod). I am now listening to a track from YouTube thrue my MacBook and Beomaster 901 - (MacBook: volume at max - BM: volume at 4/12).
     Track tip: search the forum for the B&O stereo cha-cha-cha and download it! That will be fun listening with any B&O! :)
    Bang & Olufsen - The art of controlling sound, picture and light
  • 09-01-2008 12:55 PM In reply to
    • Alex
    • Top 25 Contributor
    • Bath & Cardiff, UK
    • Posts 2,990
    RE: iPod volume, it depends on the model and where you bought it. Some of the iPods (the latest ones) are certainly quieter than line level at full volume, whereas the previous generation of iPods were much higher than line level at full volume...
     Weekly top artists:
  • 09-01-2008 5:23 PM In reply to
    • henrik
    • Top 200 Contributor
    • Stockholm, Sweden
    • Posts 299
    Alex:
    Tip: the output of the Apple Universal Dock is not affected by the EU volume cap, so i you connect your headphones or hifi to the dock you'll get higher level output than from the socket of the iPod itself.
  • 09-02-2008 2:44 PM In reply to
    • Alex
    • Posts 2,990
    I wasn't aware of that! Unfortunately, carrying an iPod Dock with you on the bus isn't the most discreet solution Stick out tongue
     Weekly top artists:
  • 09-02-2008 3:24 PM In reply to
    • henrik
    • Stockholm, Sweden
    • Posts 299
    Alex:
    I *think* (but I'm NOT sure!) that this also applies to the Apple iPod Radio Remote. Speaking of the remote, i really really wish they'd make an iPhone compatible version of it.
